I have an MCE machine with 3 hard drives in it. drive 1 (160gig) and drive 2 (250gig) are on IDE Channel 0 and drive 3 (60gig) is on IDE Channel 2. Drive 3 is partitioned to 5gig and 55gig.
I have the OS installed on drive-3/ partition 1
Previously this was booting with C as d-3/P-1, D as D-1, E as D-2, and F as D-3/P-2. (not sure how this happened, it just did...)
NOW my PC is booting with C=D-1, D=D-2, E=D-3/P-1, and F=D-3/P-2 and I am getting "Error Loading OS"
I have too many files and programs installed to want to re-install anything.
HOW can I re-set my windows so I get C back on D-3/P-1???
Patrick
Windows MCE 2005
Shuttle SH55-J2-BK-V1 w/4.00gb Ram, INTEL i3-550, 3.2ghz, WIN7 home premium 64bit
hauppauge 950q, 1600, 1250 -
if you can't get the answer here, try
http://www.pcadvisor.co.uk/index.cfm?go=discuss.allthreads&forumid=1 -
I would try changing your IDE cables at the motherboard and exchange their two positions. Some MBs are picky about putting the boot on the second IDE channel. You could also assign the drive letters in 'Administrative Tools>Computer Management>Storage>Disk Management'. Right click on the drive and 'Change Drive Letter and Paths'.
The OS prefers to look for the boot drive to be 0,0. It sounds like a good idea to maneuver the boot drive to the first channelasdrive 1 for the most painless fix.
You must have temporarily unplugged one of your drives.
There is no need to make any major changes. It worked before, no need to change the PC dramatically, just need to put it back the way it was before.
Bios will allow changing boot order, Disk manager will allow changing assigned drive letters. -
cant get to "Administrative Tools" as I cant boot the Windows... and I didnt disconnect/unplug anything, it just happened somehow.
I did go into the BIOS and changed the drive boot order, that fixed it and my drives are back to the order they were before. I would go in now and switch the cables but then I would probably have to go into all my programs and reset the drive letters in all my settings - messy. but now it works and I know how to fix the mystery next time...
thanks for the help
PatrickShuttle SH55-J2-BK-V1 w/4.00gb Ram, INTEL i3-550, 3.2ghz, WIN7 home premium 64bit
My DR-DX5 has the dreaded non-descript "loading" error.
By Cyrax9 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 19th Feb 2011, 21:38 -
"duel boot" or "partition"
By Tbag in forum ComputerReplies: 14Last Post: 2nd Jul 2008, 23:07 -
Panasonic DMR-ES10 "LOADING"-type problem
By lordsmurf in forum DVD & Blu-ray RecordersReplies: 3Last Post: 15th Jan 2008, 00:52 -
"##sudo:" Error when loading binaries
By sokkmonkey in forum ffmpegX general discussionReplies: 2Last Post: 10th Sep 2007, 20:41 -
Avi2DVD message when loading AVI...."DV DVI Detected"
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jun 2007, 08:05
