Ok, i'm making a little short video w/ my own audio. I have 3 songs mixed together and am having problems w/ one song.
I have 3 mp3's. All three are 128kbps, 2 channel stereo, and 44khz audio sampling. But when I try to do a simple multiplex w/ my video and audio, I get the 'illegal audio stream' error. So I tested each song individually and found the one that it won't accept. I have tried converting the mp3 to mp2, to wav and then back to mp3. Whenever I convert it to mp2, TMPGenc will accept it but the mp2 file has some extra noise in the song. Same w/ wav, I converted it to WAV, and it sounded good, but since TMPGenc doesn't work w/ WAV files I then converted it back to mp3 and it worked, but w/ extra noise.
I DO have the codec or plugin or whatever that allows TMPgenc to use MP3 files. I have used mp3 files of the same quality and they have worked. Why would I get errors w/ this one song? I even downloaded a different quality version of the same song and tried it and got the same error.
The joys of downloading poorly compressed music.
Can you play back the original song ? If so, you can record the playback using something like audacity or soundforge, and save a new version.
If you can't play it back then it is obviously too corrupted to be of use. Find a different track, or buy the CD it comes from.Read my blog here.
Yes, I can playback the original format and it sounds perfectly fine. It's when I change file formats that I get the extra noise. But it won't multiplex in it's original format. I actually merge the 3 mp3's with Goldwave, which works. I have been able to multiplex mp3 audio w/ video w/o any problems via TMPGenc. I guess I could try Audiocity or the other.
Thanks!
XVID/mp3 file wont open in TMPGENc express
By efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 16:16 -
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 15:32 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
wma to mp3 errors; losing file size on conversion
By gidget00 in forum ffmpegX general discussionReplies: 1Last Post: 22nd Aug 2008, 18:48 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
