Hi!
I use ffmpegx a lot, and I notice that if I encode a video using the bitrate and resolution set by the 'auto' button (after entering the ratio, framerate, length and desired encoded size, and setting the audio to passthrough at the original bitrate and CBR), the encoded videos are often 10-15% smaller than the desired encoding size.
Is this because: I should set the audio bitrate to VBR? the nature of the video (eg. dark, or not much action) just doesn't need the the bitrate set by 'auto'? or some other reason?
PS. Please don't just read this thread and move on - if it happens to you too, why do you think it is?
Cheers,
B
Is there a tool to kind of pre-scan source files and advise what bitrates will be needed at various resolutions, rather than the default bitrate that ffmpegx calculates?
Error: File shorter than expected
By justin79 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 15th Jun 2011, 22:55 -
How is a Smaller File a Better One?
By happydog500 in forum Capturing and VCRReplies: 4Last Post: 23rd May 2011, 20:50 -
Best way to convert DV file to something that have smaller file size
By Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 06:14 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
Simple Qu.- DVD disk -> Convert/Encoded (smaller) -> play on old stan
By chi1234 in forum Video ConversionReplies: 1Last Post: 13th Jan 2008, 04:03
