Hello,
I like to use the 'Record Cropped Video' option when capturing with ATI's MMC...I like how it cleans up the edges. But I find the black bars it creates are just a tad too big.
Does anyone know if I can adjust the size of these black bars? Perhaps in the registry?
Thanks,
gammer
I know it was possible in the older versions, have not tried this on MMC9x.
Do a search in the Registry for "rtinterval". This should find you the correct section, under ATI, TV, and Capture. Look in the MPG section, you can find your preset identified by the name parameter.
If you make changes, do NOT open the settings for MMC afterwards, this will overwrite any registry changes. This means you must edit the currently selected preset.
The cropping values used to be expressed as a percentage of pixels and would go to round numbers, ie it would not attempt to crop 16.5 pixels but would crop 17.
Do report back on any success/failure. -
No luck.
I did find the Registry settings and that was handy for some other adjustments. But no luck with cropping.
Thanks anyway...
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 30th Mar 2012, 00:32 -
What are Video "Profile Formats" or "Levels"?
By HanDuet in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2011, 00:41 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 19:49 -
VRD-MC3 "Copy Protection Signal Detected: Cannot Record"
By cmwalsh in forum Capturing and VCRReplies: 6Last Post: 14th Jul 2007, 12:03
