This is my first attempt at making a PAL DVD
My set-top player plays NTSC & PAL here in the States
I'm using MovieFactory4 & set to PAL
I made smooth compliant PAL mpgs via ProCoder and inserted them into MF4
Set MF4 to "do not re-encode compliant mpgs" & burnt
The DVD came out slightly choppy telling me it may have messed with the framerate
Did I miss a setting somewhere?
The DVD plays slightly choppy on my computer, too
Haven't a clue on this one
Suggestions?
Thx
PS - It's very watchable but since I'm asking for donations for this disc, I feel it should be perfectly smooth for our PAL's.
MF4 probably converted from 29.97 fps to 25 fps by simply dropping every 6th frame. That leaves you with 5 little skips every second. Step through the video with VirtualDubMod and it should be pretty obvious.
Multi-System VCRs; PAL N tape, PAL VCR
By darito in forum Capturing and VCRReplies: 14Last Post: 17th Apr 2012, 11:54 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47
