Hi,
This is my first post here.I have been ripping and copying dvds with dvd shrink for quite some time.But although the quality is decent but when it come to dvd9 discs things get a bit blurred at times.I am planning to use the cce and then the dvd rebuilder.I downloaded the basic version but whenever i am dragging & dropping the ripped dvd files into cce they are not getting accepted.Please guide me in this matter.
DVD Rebuilder does all the work. It divides the video up into chapters, create the scripts etc required, then feeds the chunks to CCE for encoding. It then reassembles the finished disc ready for testing/burning. You should not have to touch CCE manually for any of this - let rebuilder do all the work.
Read my blog here.
DVD Rebuilder v-0.97
CCE SP Trial Version Ver. 2.70.02.10
How to configure, i think i haven't done it.Please help
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 13:25 -
cce video bitrate problem
By DSLGuy in forum Video ConversionReplies: 11Last Post: 16th Feb 2008, 12:53 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27
