How is everyone? And thanks for your help in advance if there is any help to give....
I was asked why my DVD-R's would not play on a reletives player...Well the player only
plays DVD, CD and Video-CD. Its a Samsung Model# DVD-909. I tried a DVD+/-RW and
still no go....is there a checksum or a marker I could add to trick it into seeing a pressed disk?
I hope to hear from you....
try a known good media like a verbatim or t.y. in dvd -r format burned at half it's rated speed. it can't play any dvd-rw.
https://www.videohelp.com/dvdplayers?DVDname=samsung+909&Submit=Search&Search=Search&dv...y=Name&hits=25--
changing the book type to ROM this only works with + r/RW DVDs though... thats the only way to make the player think its a "pressed" or store bought.. but its not fool proof
The capabilities and comments by some users are here:
https://www.videohelp.com/dvdplayers.php?DVDnameid=359&Search=Search&#comments -
According to the comments on your player it will play DVD+R and DVD-R but does not like DVD-RW or DVD+RW. If all you've tried is RW then that's probably the problem right there.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
Storing CDs - commercial pressed
By magillagorilla in forum MediaReplies: 6Last Post: 29th Jan 2011, 19:20 -
Can't put to work Advanced High Definition Disk Creator
By mahogany in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 04:56 -
Capturing stops when 'Source' button on monitor is pressed...
By montageman in forum Capturing and VCRReplies: 3Last Post: 24th Oct 2009, 22:54 -
New pressed DVD's won't load on DVD-Rom but will on standalone
By chemchem in forum Software PlayingReplies: 1Last Post: 8th Feb 2009, 23:32 -
Controlling which button gets focus when arrow keys are pressed
By kojow7 in forum Authoring (DVD)Replies: 7Last Post: 8th Jun 2007, 16:24
