I am wondering if there is a way of saving an Mpeg-2 movie using Virtualdub-Mpeg2. I have a movie clip that I have applied some filters in Virtualdub-Mpeg2 and would like to save it as mpeg2. However,I am at a loss as to how to do that. I would appreciate any help. All suggestions are welcome
If you do not learn from someone's knowledge and experience, then you are doing it the hard way
You can't really save as MPEG from VirtrualDubMPEG2. You can frameserve to an MPEG2 encoder via File -> Start Frameserver.
To re-encode , try here :
https://forum.videohelp.com/viewtopic.php?t=270071 -
Thanks for all the replies. What I did was to save the clip as avi, after saving the audio as wav. I then frameserved the avi clip using using virtualdub-mpeg2 and CCE basic. The wav was encoded into ac3 using BeSweet(guide avalable here) and then muxed using tmpgenc express. Now, to my biased eye it looks better than what I started with. But then it could be that I would like to think my efforts made a difference. Thanks a lot to all those who replied
MPEG2 to AVI or whatever VirtualDub will use
By bpatters69 in forum Video ConversionReplies: 4Last Post: 1st Nov 2009, 19:19 -
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 01:49 -
Help! VirtualDub video/audio out of sync when enconding MPEG2 to XVID
By kbal in forum Video ConversionReplies: 6Last Post: 19th Dec 2007, 15:05 -
Problem with Virtualdub-MPEG2
By deepakOne in forum Video ConversionReplies: 2Last Post: 5th Oct 2007, 02:35 -
Please Help! Can't Get VirtualDub-MPEG2 file size down!
By dano187 in forum DVD RippingReplies: 2Last Post: 26th Jun 2007, 19:15
