    May 2006
    United States Of America
    Hi,
    I used Audition to create a psuedo-5.1 mix in stereo that sounded really great. I then used DVD Lab to mux the audio and video into a DVD for testing. When I tested it out on WinDVD, I made sure to specify that I was using a stereo mix and to use Dolby Virtual sound for playback. This does work, however I have to crank my speakers nearly as loud as they can go in order to hear anything. It's nice to know that the results sounded good otherwise. But does anyone know why the volume came out so low? I'd rather not have to turn my speakers up a ridiculous amount in order to hear anything :/
    - Justin
    Apr 2004
    Miskatonic U
    AC3 has a wide dynamic range. That is, quiet is very quiet, loud is therefore, loud. How you mixed it, how much range you gave it, and what settings you used when encoding it determine what you finally get. However there should be no difference between the AC3 file that you produces, and the DVD. Authoring should not alter the playback. What may alter are the tools you use to play it back, which could in turn affect how loud you percieve it.
    Read my blog here.
    Feb 2006
    Canada
    In the encoding options, set "dialogue normalization) to -31db and disable any dynamic compression.
    Look at the following for more details:
    https://forum.videohelp.com/viewtopic.php?t=296900&highlight=
