Hi All, I have searched many forums and have yet to find an answer to this problem. Most, if not all, suggest using VCDToolsX. It is no longer availableI tried VCDGear1_76 but it does not reconize the program and VCDGearX does not offer a bin to mpg option. Is there some way to open a bin on a Mac? Stuffit is no help!! Or extract the mpgs'???
THanks for any help
Oh yes it is???
Every Link I've tried is nolonger in service...
I will look at Gumbie too....
Do you have a link to VCDToolsX that is still working? -
As stated previously, Gumby 50c (VCD Jelly) works.
You can also use Toast to mount it as a Disc image and then open the .Dat file with a few programs, including MPEG Streamclip, which will convert it into a MPEG. -
Click the "is" in my post or just go to:Originally Posted by glynnkjk
<https://www.videohelp.com/~tgpo/prog/vcdtoolsX.sit>
extract music from bin image?
By pensioner in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2011, 00:01 -
How to extract audio from mpg file?
By paul.1911 in forum AudioReplies: 4Last Post: 9th Nov 2010, 04:35 -
How to extract Teletext substream from mpg ?
By Robertus in forum SubtitleReplies: 11Last Post: 27th Sep 2010, 10:49 -
Extract audio from FLV (on Mac)
By matt276 in forum Video ConversionReplies: 2Last Post: 22nd Dec 2009, 13:26 -
Extract Audio from MPG
By vin4evr in forum AudioReplies: 3Last Post: 24th Dec 2007, 14:09
