What is a DVCD? My player says it can play them but i dont see anything about them here. What is it?
DVCD?
There are 2 possibilities:
1. It is CVD, a chinese version of SVCD. It is also known as Chaoji VCD and HDVCD. It is like SVCD, but the resolution is 352 X 576 (480).
2. It is X(S)VCD or MiniDVD.
DVCDs have the MPEG-1 specs identical to ordinary standard VCDs. They can (according to the hype) have up to 120 minutes on a disc but I have never credibly heard of one much more than 90 minutes.
These are mastered by stamping the disc with a tighter spiral to get the higher disc capacities.
They are otherwise the same as standard VCDs.
In a way, a normal VCD burnt onto 90/99 min media is a lot like DVCD though nobody calls them that of course.
Regards.
Michael Tam
w: Morsels of Evidence
