    Jan 2006
    Is there any easy way to take a finished VIDEO_TS folder, with menus and options and stuff, and change out one of the titles with a completely different one? For example, let's say I have I have the m2v and ac3 file for "Six-String Samurai" and a VIDEO_TS folder for "Seven Samurai". Can I alter the "Seven Samurai" folder so that when "Play movie" is selected, it plays "Six-String Samurai" instead?
  2. I've never tried it, and perhaps am not aware of all the factors involved. But it wold be very easy to test. Give the replcement movie vob files the same names as the ones you want to replace. Do this is a copy of the VIDEO_TS folder. Then use DVDPlayer to see if it plays the way you expect it to. There's no need to multiplex or burn a DVD to find out. It is possible that the length of the vob files or some other factor would need to match....I'm not sure. The IFO files are an important factor in a situation like this, I suspect.
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    the IFO would determine the runtime and length
    of each individual VOB. so if VOB one through three
    was 25mins, and Vob four was 15 mins, and you
    substituted it with four VOBs, one through three at
    25mins each, and VOB four at 11mins, the IFO
    when read would return a mis-match in structure,
    just like it does when say you rip an ArrCCos release
    DVD, and the padded bad VOBs if removed/changed,
    do not let you re-quantum the disc.
    So without an IFO editor, I'd say no way it will work.
    And if you are going to edit the IFO, you might as well
    just be safe and re-author at that point.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Jan 2006
    Interesting. Say, for the sake of argument, that the swapped titles happen to be exactly the same length, would that work, and is it as easy as Willrob suggests? Suppose the two titles are the same length, but due to re-quantizing they're not exactly the same file size?
  5. Member terryj's Avatar
    read further here:
    what's in a DVD?
    In your question, I'd still say no, because I had forgot this earlier,
    and that is the IFO also contains chapter marks for
    navigation, so that in creating its "roadmap" for you the user,
    when you play the DVD, it knows not only the times/run length,
    and the amount of VOBs associated with each IFO in a set
    (VTS1.IFO and VTS1-4.VOB, as well as VTS0.IFO, and VTS0.VOB,
    etc.), but what chapters SHOULD be contained within that VOB set.
    and Chapters as we know, are placed in Authoring.
    Again, so I don't think it would work, based on this,
    without editing the IFO, but in Editing an IFO ( and then
    re-creating its necessary BUP), you might just be better off
    re-authoring the disc.
    Urban Mac User
    Jan 2006
    I might seems like I'm beating a dead horse, but I'm finding this fascinating. Given everything you've said, consider: A completely different movie, BUT it is the exact same length as the original, AND the chapter breaks happen to be at the exact same times. (Same numbers of audio/subtitle/angles/etc.) Everything's the same, just that the m2v and ac3 are a different show. Do the VOBs swap cleanly then?
  7. Member terryj's Avatar
    try it an see.
    Urban Mac User
