I am trying to add 2 audio streams and one OGT set of subtitles. When muxing, it first gives me an error that the max bitrate is 2968000, but then it proceeds anyway. After going through all the video and both audio streams it then crashes with no warning or error.
I have the Pure VBR box checked but the PS format box is unchecked.
I also used a subtitle start time of 0.5 as recommended on the doom9 site.
Anyone seen this one?
Ok, new news:
If I only try 1 video stream and 1 audio stream with subtitles, I get the error "OGT Channel 1, first time over".
So I tried reducing the audio bitrate from 224k down to 192k, and then finally down to 128k -- same deal.
My video stream has a 2-pass VBR avg bitrate of around 1200k and the max was set to 2520k in TMPG -- these numbers all came from the bitrate calc to fit an 80 min CD. I am not looking forward to re-encoding that as it took 25 hours.
1) Does I-author support 2 audio + 1 subtitle simultaneously?
2) What do you have to do to your audio/video to get I-author to take it without errors?
FFDSHOW won't install on Win2k
By DanielF in forum Software PlayingReplies: 7Last Post: 27th Apr 2013, 05:12 -
Missing or corrupt file in Win2k
By bevills1 in forum ComputerReplies: 8Last Post: 10th May 2008, 20:43 -
Win2K hangs during booting... :-(
By spiffy in forum ComputerReplies: 3Last Post: 9th Apr 2008, 13:23 -
windows explorer in win2K
By fjmr in forum ComputerReplies: 10Last Post: 4th Oct 2007, 17:37 -
What does win2K need for WinMediaPlayer9 to work ?
By DBenz in forum Software PlayingReplies: 2Last Post: 1st Sep 2007, 11:21
