I have a question I wanna burn 4 episodes of anime onto one disc each file is 170 megish .avi files if i reduce the quality to take up say.. 25% of the disc will the change in quality be drastically noticable? is there any other way?
Thanks for any help i can get!
Also I alwayts have a problem when burning fansubs.. the subtitles almost always seem to get cutt off the screen at times any way i can fix that?
1. Bitrate calculator - use it to determine the bitrate you need to encode at. 170MB would be around 30 minutes, x 4 = approx 2 hours running time. If so, this should fit comfortably. Work out the exact runtime, then use a bitrate calculator to work out the numbers for encoding.
2. Use FitCD to create an avisynth script that will reduce the size of the video, then add a border. This will force your subtitles back into the visible area. Use the avisynth script when encoding instead of the avi file. For more details, read this post -> https://forum.videohelp.com/viewtopic.php?t=302970Read my blog here.
so i just calculate what bitrate i should encode at by doing RUNTIME X 4 ?
Ok the total runtime is 96minutes 36 seconds im using the videohelp bitrate calc.. i will be using 4.7gb dvd+rs please tell me how i calculate and encode at a certain bitrate I am HORRIBLE at math -
OK. You click on the following link -> https://www.videohelp.com/calc.htm to load the Videohelp online bitrate calculator. Enter the running time in hours minutes and seconds, then look at the number at the bottom marked Calculated Bitrate. In your case, it will be around 5994 kbps, depending on what bitrate you use for your audio. If you have stereo mp3 audio on your avi files, 192 kbps is OK for your audio, and will give you more bitrate for video.
Use the calculated bitrate as the average bitrate in your encoder if you use VBR encoding, or as the bitrate if you use CBR. Personally, at this rate I would use 2-pass VBR.Read my blog here.
Shrink Xvids to fit episodes on DVD
By Wolfbrain in forum Video ConversionReplies: 5Last Post: 20th Apr 2009, 12:40 -
Adding 13 Anime Episodes to 1 DVD?? How is it Done?
By sandman423 in forum Newbie / General discussionsReplies: 34Last Post: 9th Aug 2008, 01:06 -
Creating dvd video with 20+ episodes of anime
By kurt_tml in forum Authoring (DVD)Replies: 9Last Post: 21st Jul 2008, 19:26 -
Anime Episodes have to much Overscan on my TV..How do I Fix?
By sandman423 in forum Authoring (DVD)Replies: 18Last Post: 6th Jul 2008, 21:20 -
how to fit more than 2 episodes on a DVD and be compatible with all players
By brentonboy in forum Newbie / General discussionsReplies: 18Last Post: 20th Nov 2007, 03:35
