I would like to store my MiniDV tapes on a hard drive, so I can edit the movie later. Of course the least lossy solution would've been to use the native DV AVI format, but it is too huge. What other format would you recommend ? I am using "Windows Movie Maker", and it offers options like "High Quality Video", "Video for Local Playback 2.1 Mbps", etc, but I am not sure which one would allow further editing with minimum loss.
Thanks for your help.
Results 1 to 9 of 9
Offhand, I'd suggest buying a huge hard drive and storing them as DV.
DV is the ideal format for editing. Any other format that retains the same quality will take up even more space. Any format that takes up less space will reduce the quality.
Put the tapes somewhere dark, dry and safe until you are ready to edit.Read my blog here.
might be cheaper and easier to just leave them on tape, and buy new tapes at $2 apiece.
What application should I use to store a DV AVI stream as a high bitrate MPEG2 ? I don't think that "Windows Movie Maker" has this option.
Any good quality mpeg-2 encoder - ProCoder, CCE, Mainconcept or Tmpgenc would be my recommendations. I would only use tmpgenc if you have a very fast machine or are patient as it is notoriously slow.
Only go down this route if you intend to do very simple editing - basically just cuts. Mpeg-2 does not like being compressed multiple times. Simple cuts can be done without the need to re-encode. Crossfades, overlays and other fancy effects will require re-encoding, and will often show up compression issues.Read my blog here.
BD backup file storage: which format? H.264, .mkv, .m2ts,
By jlm86 in forum Blu-ray RippingReplies: 6Last Post: 21st Feb 2011, 15:27 -
Trying to convert dvd's to a format optimized for streaming to an 360 WMCE
By 456killers in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2010, 04:42 -
Long term storage format.
By DaveQB in forum RestorationReplies: 1Last Post: 23rd Oct 2009, 07:37 -
Best lossless format for storage/future editing for Hi8
By jkryan in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2009, 23:33 -
Best format for storage
By trikcard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Apr 2008, 10:18
