We record conferences and like to have DVD's available soon after the last session. Currently we used DVD hardrive recorders but are not happy with the menus. I know it is possible to encode directly to mpeg2 and import those into a DVD author so the question I pose to y'all is what hardware, software and procedure might we follow to be successful.
I have tested some solutions with mixed success, such as MainConcept capture to mpeg2. Using a Xeon 3.0 Ghz with 2GB of ram the audio was choppy, using the defaut dv setting it was fine encoding to avi then converting to mpeg2.
I have seen some hardware encoders but would like to hear from the community as to the best way to solve this problem.
Thanks!
Personally I use a DVD recorder as my capture device then I re-author with TDA to create new menus. I rip the DVD with DVDDecrypter in ifo mode, edit with MVW if necessary, author with TDA.
More info here: https://forum.videohelp.com/viewtopic.php?t=224833"Art is making something out of nothing and selling it." - Frank Zappa -
Have a look at Ulead DVD Workshop. It can encode to mpeg during capture and you could also have some preset menus already written ready to go. The encoder doesn't do a bad job as long as you keep the length per DVD down (no more than an hour per disc). There's a 30 day free trial you can download from www.ulead.com.
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 11:50 -
Quickest method of converting avi to DVD ???
By blinky88 in forum Video ConversionReplies: 15Last Post: 10th Oct 2009, 01:09 -
Quickest way from Camcorder to DVD
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 25Last Post: 26th Aug 2009, 13:07 -
What is the quickest way to get an mpeg onto a playable dvd?
By pugvader in forum Newbie / General discussionsReplies: 4Last Post: 1st May 2009, 14:57 -
Quickest Way to Rip My DVD's?
By Rjupiter in forum Newbie / General discussionsReplies: 16Last Post: 19th Mar 2008, 13:11
