ok ,this is my first atempt. i took an avi,encoded to vcd mpeg1,then used nero5.5 to burn as a vcd, on the disk it created folders, in the folder \mpegav their is my movie, avseq01.dat I can open this with media player and it works fine but on a sony stand alone dvd (it says vcd right on the faceplate) it wont evan see the disk. have i missed a step? or do i need to do something with the player? can the dvd see the file in a folder?thanks
Eric
That's right.
Unfortunately, many people don't understand that VCD compatibility HAS NOTHING to do with CD-R/W compatibility. If you player doesn't say that it can play CD-R or CD-RW media, then it wasn't designed to do so. Those players that are designed to read CD-R and CD-RW media will have this fact in the manual.
If you have one of those players that don't play CD-R or CD-RW media, you may still be able to find a brand of media that does work. It comes down to you experimenting with different brands. CD-RW often works better in these cases.
Regards.
Michael Tam
w: Morsels of Evidence -
thanks, i did in fact use a cdr,its a sony c660, according to the compatibility list it can play cdrw. so i'll try that. if it does work should it play automaticly or do i have to do something to the dvd to find the file.thanks again
Eric -
Try Mr. Write CD-RW. It works best. You can order online from http://www.computer123.com at $3.50/10 pcs. Browse:Media, Brand: Friendly CD Tek.
Ink cartridge cannot be reconized
By Teac23 in forum ComputerReplies: 2Last Post: 2nd Mar 2011, 11:04 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15 -
Upconversion DVD player w/ S/VCD
By Clessoulis in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2008, 09:43 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 07:41
