how do i make these graphic? is it hard to make? what program do i use?
what im trying to do
im trying to make graphics (words) that look just like the LOST logo. the words will be under the LOST logo alittle smaller then the logo. if you have not seen the LOST logo. the logo starts small and spins torwards the srceen untill the logo disappears. i want me logo to do the same but stay under to LOST logo. the LOST logo is DVD format mpg (ripped from my lost DVDs)
how can i do this?
heres some pictures of of what i want the mpg to do (red is were i want the words to be)
Results 1 to 11 of 11
You could just edit that frame by frame... Or do you need something else altogether?
what program should i use?Originally Posted by kschang
i have MPEG video Wizard but i dont think it can do what in need too do. does anyone know if MVW can do this? -
I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
Here is a very quick example using your image. Obviously you could do much better if you took your time.
lost.avi
Can't understand why anybody would want to put their logo on somebody elses work though?I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix, -
ok thanks ill try it outOriginally Posted by dipstick
i have my reasonsCan't understand why anybody would want to put their logo on somebody elses work though
I have used photoshop to design the text then created the animations for the scene in flash > export to avi and your done..
You would have alot more flexability with the animation in Flash
you could use coffeeCup firestarter as an easy alternative but it does have limitations -
this avi is what i want to doOriginally Posted by dipstick
can someone help me make this avi step by step? i tryed to pm dipstick to help me but i didnt get a reply
he must be bizzy.
thanks
How to Install Windows 7 O.S on new Internal Hard disk & make Partition ?
By skorpinok in forum ComputerReplies: 10Last Post: 26th Aug 2011, 07:13 -
How to make subtitles HARD in DVD
By blue2 in forum Authoring (DVD)Replies: 4Last Post: 14th Mar 2009, 13:27 -
Can ImgBurn Make an Image of a Hard Drive on a Computer?
By drstew in forum Newbie / General discussionsReplies: 2Last Post: 28th Apr 2008, 08:00 -
how do I make video available for downloading onto the users hard drive?
By frankri in forum MacReplies: 2Last Post: 9th Apr 2008, 16:42 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 09:47
