Results 1 to 11 of 11
  1. Member spiritgumm's Avatar
    Jan 2004
    Are dvd+r better (more universally acceptable) because the booktype can be changed to dvd-rom? If so, is this true for Dual layer dvd+r too?
    On a tangent, I've noticed dvd+rw can be played right out of a stand-alone dvd recorder, whereas dvd-rw need to be finalized. Also my Philips/Benq burner wouldn't recognize dvd-rw made in a dvd recorder, but no problems with dvd+rw. Seems like +r has other advantages.
    Absolutely not.
    Prior to booktype setting abilities, DVD+R media only had a compatibility in the low 80% range. By adding the ability to booktype DVD+R, the media is now very close to DVD-R at just under 90% overall (DVD-R is just above 90% overall).
    Now, with DVD+R DL, this does help some, because it lets the player know a 2nd layer is allowed. This does nothing for raw hardware/reflectivity compatibility, but is does help with layers when the disc can be read.
    DVD+RW uses the DVD+VR recording method, which precludes the need for a finalize on that type of disc. Unfortunately, DVD+VR technology suffers from several drawbacks, including CVBR and the tendency for IFO files to corrupts (on DVD+R or edited DVD+RW). And then DVD+RW really does not last as long as DVD-RW media, lots of issues out there where discs develope craters in just a few months. Watch for that if you use DVD+RW media.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Really????
    I bought a 25 pack of Memorex +RW's for my liteon dvd recorder.
    Should I preserve what I want to save and buy a pack of -rw's instead? My liteon can record to both - and + rw's.
  4. Member spiritgumm's Avatar
    Jan 2004
    Thanks! I only use dvd+rw for temporary data storage (like in a dvd recorder or test-burns), but I can forsee their degradation being a problem.
    So ultimately, which is the "better" Duallayer media to use? Dvd-r or Dvd+r? It sounds like they have their pros and cons.
  5. Member Marvingj's Avatar
    Apr 2004
    Death Valley, Bomb-Bay
    I personally like DVD-RW Better than DVD+RW.
    http://www.absolutevisionvideo.com
    BLUE SKY, BLACK DEATH!!
  6. I've been using same +RW's for the last 3 yrs....still working. why is -RW better?
    it's just a matter of preference, some like + some like -.....
    I have preference to neither disc type. I've come to understand which discs suit which purposes. For example, in a picky DVD player, it's often required that a MCC DVD-R be used. Or that my XBOX can only read DVD-RW and not DVD+RW.
    But the problem is not whether DVD-RW is "better" than DVD+RW, but rather that quite a few people are having issues, and it's been this way for a few years now, with DVD+RW discs not lasting as long as they should, even in ideal storage/usage conditions. There is a longevity concern, so carefully scrutinize the bottom of the discs and look for craters in the phase change material before using it.
    From personal experience, for example, I have DVD+RW discs from mid/late 2003, but it's only about half or less of the amount I once had (Sony, MCC, Infodisc, you name it). Comparatively, I still have every single DVD-RW stretching back to early 2002. The only reason I've had to toss a DVD-RW is because it was scratched too much (I was careless and did not store it properly at all times), and then the odd Ritek RW disc from time to time.
  8. Member spiritgumm's Avatar
    Jan 2004
    Getting back to my original question (which wasn't about the merits of +-rw), which is the "better" Dual Layer media to use? Dvd-r or Dvd+r? It sounds like they have their pros and cons.
  9. for DL media + is all the way, just because of the booktype. the players weren't designed to play - or + DL, but when you change the booktype to dvd-rom, you fool the player to think it;s a pressed disc.
  10. No offense Lordsmurf but you have always been pro "-R",longevity has nothing to do with format.I am not advocating either format but you should use what works on your players.
    That being said:using "+R" on standalone recorders has better PC compatibilty because DVD+VR is closer to DVD-VIDEO than DVD-VR.DVD+R also has the advantage of multi-session when writing data.I haven't tried -R DL but have had 75% success with +R DL.
  11. Video Restorer lordsmurf's Avatar
    MOVIEGEEK, disc type and recording type are not combined.
    DVD recorders that adhere to RW Alliance specs must use DVD+VR recording types. For example, LiteOn equipment is stringent to DVD+VR standard ... even on DVD-R or DVD-RW media. DVD+VR is a DVD-Video standard, but with limited options (such as requiring CVBR and MPEG Layer II audio, with AC3 as optional).
    DVD-VR is an optional recording method in machines that are using the DVD Forum's DVD-Video standard. They can do either "VIDEO MODE" (DVD-Video) or "VR MODE" (DVD-VR). I never suggest DVD-VR, avoid it at all costs. It sacrifices compatibility for some better editing abilities. Edit on a computer or don't edit, assuming you want a DVD-Video disc.
    Longevity is indeed affected by format, but only because the materials used in the discs vary. This is why a DVD+R and DVD-R are not identical, a myth long ago buried.
    With more companies like TY and MCC and MAXELL now making DVD+R media, there is finally something decent to choose from. No longer is DVD+R stuck with RICOH and CMC only.
    There are still compatilibity concerns with DVD+R being less than DVD-R, but even then you cannot just grab any DVD-R and solve the problem. As suggested earlier, in that sort of situation, you must not only get a DVD-R, but an MCC-made DVD-R.
    There's no reason to be "pro" for either format. Use what the situation requires, considering a list of circumstances.
