I use avi2vcd to convert to mpeg then VCDImagerGUI to make bin/cue then Cdrwin to burn actual VCD.
The problem occurs when i converting to mpeg, made many a coasters in this process.
The Conversion makes the video portion into stills but the audio works fine. Thought it was the bin/cue convertor, but have had some success with some avi's,narrowed it down to the mpeg convertor. Is there a better convertor or program that can stop this process.
Results 1 to 9 of 9
Use TMPGEnc (not the fastest, but free) or a commercial encoder. AVI2VCD is REALLY slow, even slower than TMPGEnc and seems to be not very reliable as you report.
But keep the Decompress.exe from the AVI2VCD package. Sometimes TMPGEnc doesn't like compressed audio. Decompress.exe is very helpful in such a case. It decompresses the audio to PCM and you get a new AVI which can be converted with TMPGEnc. -
Ooops, Cheewy was faster...
But I think www.tmpgenc.net/ is more up-to-date.
v2.50 is currently only available there.
<font size=-1>[ This Message was edited by: Headhunter3000 on 2002-01-06 18:20:52 ]</font> -
Can someone help me, please?
I have a Canon Powershot S110 that capture movies in avi format, but they can be played only on quick time 3 or higher. I can´t convert them to mpeg, even with TMPGEnc.
There is a movie sample on http://www.steves-digicams.com/2001_reviews/s110_pg3.html
I hope someone can help me, thanks. -
Sorry, the movie sample is here:
http://www.steves-digicams.com/2001_reviews/s110_samples.html
MARCOPOLORIVERA: you need a mjpg codec. Huffyuv is freeware and will moast likely work for you.
http://www.math.berkeley.edu/%7Ebenrg/huffyuv.html
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
Huffyuv is NOT an mjpeg codec.
Download the Pegasus mjpeg codec from http://www.picvideo.com instead.
Huffyuv is an efficient lossless codec which is especially useful for high quality capturing.
Cheers
Having problems converting FLV to mpeg with Freemake video downloader
By sarbot in forum Video ConversionReplies: 10Last Post: 11th Sep 2010, 22:41 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
converting mpeg to avi
By extremebeat in forum Video ConversionReplies: 1Last Post: 24th Feb 2009, 14:07 -
converting avi to mpeg-1 help plz??
By darealest1 in forum MacReplies: 5Last Post: 12th Jul 2007, 22:43 -
Problems converting HD Mpeg
By fearmyrage in forum Video ConversionReplies: 3Last Post: 7th Jun 2007, 23:46
