I have the TDA single layer version. I just bought a Pioneer 111 dual layer drive and I'll probably experiment with dual layer discs.
Can I simply author to 8gigs and click ignore with tda and burn the 8gig folder? Or do I have use a dedicated dual layer authoring program to set the layer break? Can I use dvd decrypter to burn the 8 gig folder from tda and have that automatically set the break point?
Also, if I have to buy a new program to author dual layers what would be a cheap alternative to a new version of tda?
use the newer version of decrypter - imgburn and you can have it set the layer break. i re-read your buying thread and went to newegg and got a 111d beige for $37 with free shipping myself.
i'm not putting up with shoddy lite-on burns anymore.
i use dvd-lab pro, it will author dvd9, but with the price of dual layer media still so high i have never bothered. as long as i can keep the video bitrate over 3000 vbr, no one has ever complained.--
Bump
Well I decided to buy TDA version 2.0. I did want the integrated dual layer option after all.
I do have one question - is there an update for it to include 16x burning for single layer discs (and yes the discs are 16x)? It only seems to go up to 12x even though is a 16x pioneer 111. I bought it and downloaded the other night so I would imagine its the latest version.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Dual Layer burn issue with TMPGEnc Authoring Works 4
By am_dew in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2012, 08:36 -
Question on Dual Layer burning....
By ranchhand in forum DVD RippingReplies: 12Last Post: 4th Dec 2010, 16:26 -
Dual Layer Question
By wulf109 in forum DVD & Blu-ray WritersReplies: 1Last Post: 7th Jul 2010, 16:53 -
By miniboss91 in forum Authoring (DVD)Replies: 2Last Post: 20th May 2010, 02:37 -
Burning dual layer question
By ny888 in forum DVD & Blu-ray WritersReplies: 2Last Post: 4th Dec 2008, 18:01
