is there any way you can add visualization to the disc so that instead of looking at a black TV screen while I listen to the music like on media player? are there specific programs that can create it?
Results 1 to 11 of 11
I used the album cover and make a slide show for the music. I also known a guy rip the video from Karaoke/new age video, and replace them with his own sound track.
well i'm thinking more like the visualizations like in media player moving colors and stuff instead of straight pics like in a slideshow
similar to http://alittlespace.biz/alsv/
but created by me -
Good idea.
Get a copy of this freeware : http://www.snapfiles.com/get/aviscreen.html
1. Install the avi screen capture classic.
2. Start the capture as full screen, at 30 fps.
3. Start the media player with the music.
4. At the end of the musci, click on the taskbar avi screen capture icon, and to stop it.
5. Open TMPGenc, and select DVD as output.
6. Import the avi from "C:\Program Files\bobyte\AviScreen classic\Captures"
7. Import the music track.
8. Goto TMPGenc adavnce menu, and select clip frame, and crop away the white borders.
9. Encode.
10. Done, kick back and watch the show. -
thanks i'll check them out
i found an excellent one apollo audio dvd creator but it only makes a static background picture. i need moving things so the tv screen dont burn in. -
great method but even at 30fps the video is choppy
Originally Posted by SingSing -
there should be a piece of software made to do this in my opinion
Music Video Question
By budwzr in forum EditingReplies: 0Last Post: 17th Nov 2010, 22:07 -
Zealsoft Music DVD Maker question
By mysts in forum Newbie / General discussionsReplies: 9Last Post: 15th Sep 2008, 07:33 -
Music Library Question
By wwaag in forum AudioReplies: 0Last Post: 23rd Aug 2007, 14:58 -
A question about the acquiring of music.
By gary431 in forum Off topicReplies: 3Last Post: 19th Aug 2007, 18:28 -
TmpgEnc DVD Author 3 - Question About Menu Music
By heyjjjaded in forum Authoring (DVD)Replies: 10Last Post: 30th Jul 2007, 13:16
