I just wanted to mention that there seems to be some discrepancies in the instructions for installing the RealVideo support files.
The instructions say to use the "macos-gcc3-pb" / "All clients" link at http://forms.helixcommunity.org/helix/builds/?category=helixdnaclient
However, there does not seem to be a link for "macos-gcc3-pb"
Thanks.
The instructions also state: If you have problems in getting all the above, or if the recent build does not work well, you may download instead a stable build of reallib from this link.
Edit: Ah, TugBoat beat me to it.
I've experiences the same problem as the only download seems to be for linux, including the stable build. Anyway i downloaded the folder and placed it in the ffmpegx folder of the application support but .rm conversion is still not possible. Not only that though, but it can't even get to that stage, as soon as you attempt to open the .rm file ffmpegx hangs for about a couple of minutes.
I had the same problem as Muzzlebogan, but then I let the application alone for half an hour (!) or so, the RM file finally loaded (time probably depends on the size of the file). But then comes the next problem: it seems that some RM files can be converted and some can't. Files encoded with the RV10 and RV20 codecs seem to work, but RV4O files definitely don't work. One reason may be that MPlayer can't play them (just sound with no picture). So that's why nothing happens when you click the Play button. As stated on the ffmpegX homepage: "To test your reallibs install, open a RealVideo file in ffmpegX and click "Play". If you see the movie, then the install is successful." Well, sometimes you see the movie, sometimes you don't. Anyone has an idea how to convert RM files with RV40 (Real Player 10 format)? And also: why does it take half an hour to load a RM file? It's very quick with other files. Thanks to anyone who has an idea.
Not able to encode realvideo with ffmpegX on MacOS SnowLeopard
By oicram in forum ffmpegX general discussionReplies: 2Last Post: 10th May 2011, 14:55 -
What tool is idea to convert the RealVideo VBR into the DVD?
By coody in forum DVD RippingReplies: 1Last Post: 23rd Aug 2008, 10:16 -
RealVideo Source to MPEG2, problems.
By mattstan in forum Video ConversionReplies: 5Last Post: 4th Aug 2008, 05:06 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
converting RealVideo 10 to avi
By user543 in forum ffmpegX general discussionReplies: 2Last Post: 30th Oct 2007, 02:06
