Hi,
I'm not sure, but I think my question might be related to what the previous thread was about. I'm starting a new thread, since I'm not positive that this is the case. Anyway...
Since I don't (yet) have a 5.1 setup, all I can do is create a Stereo mix. Well, that's not ALL I can do, but I won't get into the other details.
My question is:
Since Adobe allows you to adjust the panning and volume levels of each track, isn't it possible to create a psuedo-5.1 mix in Stereo, by making sure you properly adjust the panning and volume levels per 5.1 channel? Can't all 6 channels be incorporated into a Stereo mix, just by making sure you've panned and adjusted the volume of each channel properly, to avoid clipping?
For instance, you have a Stereo track, with left/right channels. Can't you assign the FL to the left channel, panned 100 left and the FR to the right channel, panned 100 right? Then, apply the C to both channels, panned at 0, the LFE to both channels, panned at 0, the SL to the left channel and the FR to the right channel? I'm not sure what volume the C and LFE channels would be or what the volume AND panning to the SL/SR would be. However, if you adjust each channel appropriately, can what I'm thinking be done? If not, can someone explain why? If so, can someone recommend what volumes/pannings would work well?
Hopefully, I didn't sound like a complete moron here :/
Thanks in advance,
Justin
Simulate green areas of bad compression
By elmuz in forum EditingReplies: 5Last Post: 24th Mar 2011, 06:28 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 09:33 -
512x288 or 352x288 and streched player to simulate 16:9
By Fking in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2008, 08:30 -
Shareware to simulate mouse movement?
By atihelp in forum ComputerReplies: 2Last Post: 24th Jan 2008, 12:20 -
[?] Simulate a Tattoo?
By #1 Stunna in forum EditingReplies: 28Last Post: 28th May 2007, 13:31
