Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 19 of 19
    Jan 2006
    Australia
    Right! I dont want you purests argueing that you cant get 5.1 from stereo, thats not what this post is about.
    Here is the thing...
    I would like suggestion to software that may exsist that will allow me to add left and right channels to the left rear and right rear channels aswell as mix to center. Further I would like to have control over the "level of volume per channel" so that i can control the illustion of audio perception...
    I must be able to control each track seprately while working on all tracks at the same time.
    I would like to then save this 5.1 file and mux it into my video....
    After all you hear audio direction from where it is the loudest... thats 5.1 enough for me!
    ps Adobe Audition is hopeless... maybe some pointers then?
    Jan 2004
    Sony Vegas.
  3. Member dipstick's Avatar
    Jan 2005
    Dark side of the Moon
    http://www.stevethomson.ca/vi/
    It works great for me. It is a bit of work though. You will need software that supports vst plugins. You can use Kristal Audio Engine (free), but it will only export 3 seperate stero tracks. You can edit all 6 channels, but the s/w will only export 2 channels at a time.
    I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
    Jan 2006
    Australia
    I have sony vegas 6 and have only access to stereo settings when working from a stereo source? the surround panner doesn't work with stereo source? could you explain?
    I'm more a premiere man... so i maybe missing something
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    yep, sony vegas for this works fine -- add a bit of delay in the rear channels also ....
    but most receivers have surround modes that do a better job (DTS NEO setting foir example), though i dont like those settings and prefer to just use 5 or 7 channel stereo
    Jan 2006
    Australia
    Yeah i got that Vi and couldn't generate rear signals with premiere pro. If you can only export stereo with Kristal how do you compile the 5.1 file ??
    Jan 2006
    Australia
    remember that we are trying to use a stereo source... how am' i going to add delay to rear channel if there is no rear channel to start with? or are you saying that adding delay will create a rear channel from my stereo source?
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    go through your manual = set up project for 5.1 , the surround pans work inreal time even and are key framed or just set up to a settings you want through out ...
    seperate the stereo into 2 mono channels , L and R , put them on the audio tracks 7 times , mix one set of l and r into mono center , one set for front l and r , one set for rear l and right , and one set mixed into mono for for LFE ..
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    render to ac3 5.1 after you like the mix , rears are ussually 6db down and 3-7 ms delay, lfe is ussually +3db from front , with a 120hz low pass filter w/ a 18db per octive rolloff , center will need to be made -6 because it is summed
    Jan 2006
    Australia
    Thanks BJ_M that is very helpfull and much appreciated...
    oh and what a manual?? sorry about that then
  11. Член BJ_M's Avatar
    Jul 2002
    Canada
    the manual you got when you bought vegas , it is pretty complete ....
    Jan 2006
    Australia
    yes! well on my way now... thank you and any other software suggestions are welcome....
  13. Член BJ_M's Avatar
    Jul 2002
    Canada
    there are various plug ins for sony (and works on other programs) that can do surround effects also - a google search will turnup several .....
    but not really needed for a basic mix as above
    Jan 2006
    Australia
    I'am suprised that there doesn't exist software that simply shows a number of channels (like the look of tracks) that you can master. double click on a channel and enter the track list to master effects in each channel. That i guess it is just too simple to bother with I guess, but what an advantage it would have over these frustrating plugins that all have compatability issues. just add tracks to your channels, master the channels the way you wish and save!
    May 2006
    United States Of America
    Hm,
    I'm a bit confused here. I'm using Audition. Should I take the 6 channels and use them in the multitrack view? If so, I'm not understanding how each channel should be panned and "volumed". Also, the SL/SR should both be 3-7 ms delayed?
    Sorry for being a bit of a dope here
    - Justin
  16. Член BJ_M's Avatar
    Jul 2002
    Canada
    yes - it is called sony vegas and already exists ...
  17. Член BJ_M's Avatar
    Jul 2002
    Canada
    Originally Posted by takearushfan
    Hm,
    - Justin
    i dont use Audition
  18. Hi folks,
    Here are some guides that will help you with stereo-to-5.1 conversion:
    GUIDE: Using Adobe Audition 1.5 or 2.0 to create 5.1 files uses the three 2-channel plugins that come with V.I along with Audition's Multitrack mode to export a 6 channel wave of Windows Media Pro file.
    Creating a Pseudo 5.1 Mix from Stereo Source Using V.I. (uses Sound Forge and Vegas) uses those same three plugins but in the Sony software packages, plus exporting a finished AC3 file.
    GUIDE: Converting stereo to 5.1 surround for FREE can be helpful to those using Kristal Audio Engine to generate three 2-channel files. This guide was written for using the three V.I 2-channel plugins with Foobar2000 v8.3, but it has a section explaining how to take the three 2-channel files and create either 6 mono files or one six-channel file.
    GUIDE: Using Wavelab to create 5.1 files explains how to use Wavelab for this process.
    GUIDE: Using the V.I Stereo to 5.1 Converter in Nuendo and Cubase SX provides the steps for using these apps.
    GUIDE: Using V.I with Plogue Bidule gives you info on creating 5.1 mixes in Plogue Bidule. Until Sept. 16, the new demo of Plogue Bidule is free for use. This is probably the most powerful choice and overall one heck of a cool program.
    GUIDE LIST: Stereo-to-Surround Conversion Guides is an overall list of guides, if you want to try some other methods for converting stereo to surround. Some of these use Graphedit and DPLII software in popular DVD apps, some use Audition, some use other approaches such as DOS programs, Ambisonics plugins, etc.
    The main thing is to remember that very few commercial 5.1 releases you get on DVD actually recorded with 5 channels. Most simply apply effects and panning to create 5.1 mixes. The only real difference between these commercial releases and what's done in these guides is that the guides start with a finished stereo mix and attempt to extract information or else synthesize space. The pros with access to multitracks simply pan a sound to a channel or between channels and then perhaps apply some reverb. If you come up with something that sounds good to you, it's really every bit as valid as a commercial release.
    Have fun!
    Steve.
    May 2006
    Thanks again,
    I'm starting to realize the enormous wealth of info. that's available on this site. Virtually every question can be answered by posting a link to a guide or another thread, heh.
    Cool,
    Justin
