hi all how can i backup my own movie with multiple angles i want to encode to get better results than transcode the actual file itself is 7.4GB, i also want to strip some bits from it, thanks.
Results 1 to 12 of 12
Your own movie as in homemade or as in a commercial disc that you own ?
What is the structure of the disc (main menu, main feature, 3 extras titles etc etc) ?
What do you wish to strip out (leave just main menu and main feature etc etc) ?
I take it your target is a single layer (4.7GB) DVDR ?If in doubt, Google it. -
remember multiple angles must be all compressed with closed GOPS with fixed lenth
hell, all i want is the menu and main movie but would it be possible to keep all angles.
About the only app that will easily keep the angles while shrinking it to fit a DVD5 is the Pro version of DVD Rebuilder, which costs a little money. Any other method just isn't worth it. If you don't have DVD-RB, then it would be better to strip out all but one angle before shrinking to fit.
It's easy to strip out everything BUT the movie with angles and the menu using VobBlanker, but unless that alone brings the size down enough, it won't do you any good. -
Yes it does. I've done several with no problem and that's one of the features it advertises.
http://www.jdobbs.com/Pages/DVDRebuilder/DVD-RB_Adv.htmFull support for video interleaving (ILVU) - re-encodes angle and seamless branching.
If it doesn't perform as advertised you should bring it up in the DVD Rebuilder forum at Doom9 where the developer hangs out. This assumes that it's really a DVD with angles. You mentioned backing up your own movie with multiple angles, but didn't answer jimmalenko's question about what that really meant. If you open the DVD in VobBlanker, does it say there's ILV and mark it as "Skip"? -
So what happened when you tried to back it up using (the latest version of) DVD-RB Pro? It didn't play right when done?
You should definitely report it to jdobbs at Doom9. He's in R1, so he won't be able to go out and get the DVD to test (R2?), as he often does, but there may be others that have done the same DVD and can confirm (or contradict) what you're saying. Really, he wants and needs to hear of any problems with his software. -
Hi-
Hehe, yeah, you have to wait 5 days. That's supposed to give you time to read up and maybe sort out your problem without asking something that may have been asked before. You might do a search in the DVD-RB forum using the error message as input. That error message sounds very peculiar to me, though, and I don't think I've heard of it before.
By the way, he doesn't really like to give advice if preprocessing has been done. That is, if some other program has been used on the vobs before being sent to DVD-RB, then he doesn't feel responsible, and I don't blame him. I might also suggest if you've removed anything, or preprocessed it in any way, that you try again, this time using the untouched vobs. DVDs with angles can be very finicky, and it's easy to unknowingly mess them up.
DVDs with angles are very difficult to reencode. I've heard that the Big Three method can also do it, but not without a heck of a lot of work that DVD-RB does automatically. I think that, unless you're prepared to strip out angles, your best bet is to try and work out the problems with DVD-RB. -
Out of curiosity, what exactly do the angles contain that is so important you keep them?Originally Posted by boldy
In my experience they just consist of a few alternate language titles and captions and you are better-off without them. One language is enough for most people.
Trying to find what program to use for multiple angle editing
By greenlanternbatman in forum EditingReplies: 5Last Post: 1st Dec 2010, 16:22 -
how do i remove an angle lock from a dvd
By animalia in forum DVD RippingReplies: 1Last Post: 10th Jan 2010, 04:11 -
Backup a multi angle DVD
By src2206 in forum DVD RippingReplies: 1Last Post: 9th May 2009, 01:34 -
Multi-Angle DVD-9 to Single-Angle DVD-5 help
By rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 21:44 -
How to add subtitles to a Multi-Angle DVD?
By cruel! in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 02:10
