So I have some .avi with two audio streams and I'm trying to disable the english one so that the japanese will load automatically when I play the files. When I go to the stream list and then disable one, and then select video--> direct stream copy and save as a new file, it'll do the quick processing bit. But ... it reports 0 audio bytes are being written. So the new .avi when replayed doesn't have any audio in it, not even the subtitles.
What am I doing wrong?
I agree it should have worked if it's an AVI. As an alternative, I'd suggest a variation of what redwudz said. Save out (Demux) the Japanese audio you want in the original format untouched (MP3, I guess). Then disable both audios, add back in the demuxed one, Direct Stream Copy the video, and Save.
Doh! Celtic druid, that's a good bloody point!
A while back I batch renamed them from avis from ogms because winamp was being stupid about the file extension.
Should I change it back to ogms, and then do the same thing? Will that work? Is there a batch conversion process? I will be doing this for like ... 90 different files. So I'd like it to be not as loopy.
Domo arigato gozaimasu!
Thank you all very much from a terribly Asian girl and her anime. -
You should... try :P -
Direct stream video programs like virtualdubmod?
By qwertman123 in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2011, 04:58 -
Best way to remove subtitle stream?
By rmdeboer82 in forum DVD RippingReplies: 1Last Post: 7th Jul 2010, 05:15 -
How to add and remove audio stream?
By albo23 in forum EditingReplies: 3Last Post: 1st Jan 2009, 09:54 -
FFMPEG Stream mapping options result in conversion failure
By JackJack in forum Video ConversionReplies: 6Last Post: 27th Jun 2008, 23:19 -
Remove 1 audio stream from VDub?
By Salva Veritate in forum EditingReplies: 1Last Post: 7th Oct 2007, 23:25
