hi
Ive always been fascinated with the ability of professional production
companies to convert old film to quality crystal clear picture dv-discs.
Mostly im wondering what software(s) is/are used to do this. All i know from my little
experience that there are no magics in this area, garbage in-garbage out...
Im not only asking for general knowledge, im interested in learning what
is available out there for improving dramaticly the quality of the picture.
thanks.
da Vinci systems Revival
DIAMANT software systems
Lowry digital botox
Red Giant Film Fix
Cineric’s Cinebase
final restoration is often done by hand in photoshop = sometimes frame by frame ("M" was done mostly by hand , 18,000 frames one at a time in PS) .
film is scanned through a wet gate after cleaning and removing splices, ussually at 4k resolution, sometimes at other resolutions (6k for 70mm, 2k for 16mm) .......
it can cost a lot of money, film fix is about the cheapest software - you can spend several million also , including nessessary scanning and/or da Vinci scan hardware (or other scanners such as the ARRI film scanner)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
p.s. a lot of it is magic and great skill
They look good, because they are re-matsered from the original that only the studios have.
Originally Posted by SingSing
this is not true quite often"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Consider it a high capital, high skill specialist business. Not much credible amateur action in film restoration.
Segmentation by skill.
1. military recon/crime forensics labs
2. the specialist houses servicing the movie/tv industry (usually small businesses)
3. mid-range (professional) film to tape transfer + high end consumer businesses
4. consumer rip off houses ("8mm to DVD"). DVD is not what you want for a master unless it's progressive data.
5. Consumer efforts, shoot video on the wall, mirrors and lenses etc.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
lol, that brings back memories...Originally Posted by edDV
one time, my high school biology teacher showed us a vhs tape of a cartoon about evolution a former teacher had recorded from film by simply fixing a camcorder onto the wall and projecting the 8mm reel onto the wall...it was obvious the teacher did it while school was in session; on the tape, you can hear the class dismissal bells and the hallway clatter that follows!
it worked, but the flicker (recording a 24 FPS film onto 29.97 FPS NTSC) was horrible...
film to dvd conversion
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2010, 19:08 -
Am totally confused with dvd film conversion.
By frenchman96 in forum Video ConversionReplies: 6Last Post: 10th Nov 2010, 10:38 -
Newbie needs explanation on film frame rate
By holeepassion in forum Newbie / General discussionsReplies: 6Last Post: 29th Mar 2008, 01:29 -
Can someone educate me why DVD-r are playing black & white
By ericnord in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Oct 2007, 07:34 -
Audio sync. Please educate me!
By jaggerdss in forum Authoring (DVD)Replies: 7Last Post: 20th Sep 2007, 06:25
