I inserted 4GB SD card to my smartphone, and something weird happens.
The card is seen as ~16.5GB (hehe, I wish it were true lol)
Is there a filesize limit Windows Mobile 2003 SE Smartphone can use?
I never had any problem with a 2GB SD cards before.
I read somewhere Windows Mobile use FAT filesystem.
So, IIRC, FAT have a limit of 2GB max, hence the problem with 4GB card, am I correct?
And if I am - here's another question: is there a way to use FAT32 filesystem instead?
Any other thoughts?
(and yes, the card was formatted)
edit:
I reformatted it and moved avi and mp3 files to it using my digital camera (since it has fast USB2.0 vs. my phone's slow USB1.0) and the phone still sees it as 16448 MB in size. Almost all files are OK, but some movies cannot be FF/REV due to supposedly "damaged headers" (but they play if started from begining using TCPMP), and few mp3 files are non-accessible either (show "!" icon and won't play at all, Pocket WMP 10 just skips them).
Yet very same supposedly 'bad' files when moved to 2GB SD card - all play normally on the phone, hmm...
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Look for a firmware upgrade. Also make sure it can read cards over 2gb.
I had a rio Mp3 player that could read up to a 1gb sd card but not any higher. You have to keep on eye on that.
Have you tried filling it up to just under 2gb? Do files play properly if you don't go beyond that limit? Maybe worth a try.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thx for reply, Mster Yoda
It reads most of the files (I fill it up with MP3s and XVID films), but it doesnt want to install anything to this card, and few MP3s are not playable, as well as 2 of the movies have 'damaged headers' according to TCPMP player (they play fine from begining probably till the end - didnt watch anything till the end yet) and as such they are not 'browseable' (can't FF/REV) so it seems it does read it somehow.
Its my beloved VOQ phone, there are no upgrades/updates since it has been abandoned by its creators (canadian Sierra Wireless - its a very typical canadian story, they often make something ahead or advanced and then they abandon it out of the sudden...).
I guess I will have to change phone soon Anyways 206MHz smartphone isn't cutting it anymore.
HDR-AX2000E & Memory Cards
By toxicquack in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 27th Jun 2010, 17:37 -
windows xp Vs windows mobile 6
By Mr anderson in forum ComputerReplies: 2Last Post: 22nd Dec 2009, 10:50 -
Coming soon: Movies on flash memory cards
By stiltman in forum Latest Video NewsReplies: 16Last Post: 4th Mar 2008, 09:58 -
About 4GB Memory
By mn072065 in forum ComputerReplies: 8Last Post: 30th May 2007, 05:31
