  1. Hi, I am having problems playing a Burned VCD with a JVC VX-42SL. I burned my VCD with Nero and with the correct settings and for some reason when i plug it into my DVD player, and press the "play" button, the PBC thing pops up then it reads the 1st and 2nd track. After this, it goes back to the original DVDplayer screen. Please someone help me! thanks..
    Jan 2002
    Malaysia
    Also happen to me. Fail to properly burn mpeg to VCD in windows XP. Tried nero 5.5.5.1, 5.5.6.4 or 5.5.6.9. Tried
    cheap media. Tried Sony 24x cdr media Tried variuos burning speed 8x, 12x, 18x ... 24x on 24x capable media
    Tried on various burner: Sony 175A( 24x), Sony 175A1(24x), Imation (12x). Result:
    5 cds cannot played on Philips standalone (error: `No CD' ) 1 cd play jerky (go-stop-g0-stop...... jerky audio and video) but 1 cd ok. All cd anyway play perfect on PC.
    not try on other standalone yet but my standalone can still play all my other cd collection.
    This only happen after upgrade/ clean install XP. Previously I use win 2000. Even after reinstall win 2000 the problem persist.
    Urgently need help....
    more info....
    I try install aspi layers... still not working.
    Off (manual/disable) imapi cd burning in xp .... still not working
    No other cd writter software installed except nero 5.5
  3. The plot thickens ... i too am using 2000 and nero 5.56 however i have found that some dvd player do work, my pioneer 626 does my other panasonic works however my mates sharp and tosiba dont, but his akai does ??? there is no consivable reason, mines the only one which is region free. but mine wont enable the menu where as my panasonic does ??? there seems to be no correlation. The only thing i thought about was weather disabling the cd-i function would help.
    Any thoughts ....
    Feb 2001
    Palmdale, CA
    toshiba's are terrible at playing vcd's, very few will ever work, JVC's are not far behind but you can get them to play by finding the right media, they are very media brand sensitive.
    Oct 2000
    Fort Wayne, IN, USA
    I, too, am having difficulties getting my JVC DVD player (an XV-FA90BK) to play VCD's recorded to CD-R's or CD-RW's.
    If the media is the problem, does anyone have any advice on which brands seem to work best with JVC players?
    Thanks.
