I have a Sanyo DWM-370 DVD Player, which should play VCD's from CD-R or CD-RW according to manuf. info and posts on this site.
I've used TMPGenc to convert the .avi to MPEG-2,
used VCDEasy to author and burn the file once as an SVCD and twice as a VCD...
I put the CD-R or CD-RW into the DVD Player and it shows it's a VCD, but when I push play all I get is a blue screen.
The SVCD test from here worked perfectly... but it had an auto-burn with Adaptec, so I didn't learn much from it.
I would greatly appreciate any pointers or direction on what I may be doing incorrectly. Thanks very much!
Try making a VCD first and if you really want to make SVCD's then only do so once you have mastered regular VCD's.
Your post implies that you are trying to make a VCD from a MPG-2 file. You should be making a VCD from a MPG-1 file.
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 10:30 -
Again blue screen!!!
By alintatoc in forum ComputerReplies: 10Last Post: 10th Dec 2009, 15:16 -
Blue screen?
By alintatoc in forum ComputerReplies: 19Last Post: 1st Nov 2009, 07:53 -
what's a blue screen?
By aruwin in forum ComputerReplies: 8Last Post: 23rd Sep 2009, 09:56 -
Blue Screen Of Death
By Squid_uk in forum ComputerReplies: 15Last Post: 31st Mar 2008, 15:35
