I authored a short DVD video using the TMPGEnc DVD authorer. I used TMPGEnc to convert a .mov file to DVD mpeg format and then compiled a DVD.
It worked just fine on my pc and after burning it to DVD disc, it also worked just fine on my pc DVD player. However, when I tried it out on two separate DVD players connected to my TV, the video came out all choppy, with frame skips and freeze frames. Pretty much impossible to watch. What could be the reason for this?
You forgot to mention the media and burn speed you are using ... without this information no one can give you a defined answer to the issue ...
1: Your topset dvd player's may only support dvd-r .
2: Burn at 4x only
3: Poor media ... not all work well with different device's .
Remember ... a pc will play anything ... topset unit's will not (including ps2 / xbox)
As for tmpgenc ... it had issue's from day one ... and still dose ... -
Oh sorry, well I did burn at 4x. I used a Samsung Pleomax DVD+RW disc.
If topset DVD player have trouble with some discs, how is it that commercial DVD movies never have compatibility problems? -
also -- what was the settings you used ? it may be to high a bitrate
hi
i am having the same problem, i burnt a pal dvd with bitrate 2000, used a sony+-dvd writer and used a dvd+r disc.
any help
thanks
cnagra -
is it to do with the frame set?, i get an error before compiling that i can ignore saying its a non-dvd frame set. what is the ideal frame set and where do u change it.
thanks
cnagra -
Hmm it might be. I don't know a thing about bitrates. How would I know what the right rate is?Originally Posted by BJ_M
well what bitrate did you use ?
No dialogue, but other audio works fine
By MCPorche in forum Authoring (DVD)Replies: 1Last Post: 28th Feb 2012, 21:07 -
uTube Issues?? Choppy Video playback but sound is fine
By sandman423 in forum Video Streaming DownloadingReplies: 2Last Post: 14th Oct 2008, 16:47 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 03:54 -
Some XviDs play choppy on standalone DVD player, but absolutely fine on PC
By udaykhan in forum DVD RippingReplies: 5Last Post: 15th Jan 2008, 12:09 -
SVCD converted movie with choppy playback at the end on stand-alone player
By supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 11:10
