i want to edit in my own subs...i have a mpeg movie that i want to add subs to. i went to the editing help screen, and read thru their topics on subtitles, and now im here...
Do you want to create your own? You can try opening the video file in VirtualDub and apply the Subtitler filter.
This filter uses the SSA(Sub Station Alpha) scripting.
Check out http://www.virtualdub.org for more info.
I am not sure how you can edit existing subtitles extracted from DVD. -
yes i just want to create my own subs, i removed the subs during the rip, and basically have edited my own movie out of this dvd, now i need to put in my version of the subs, the problem im having is w/ substation alpha, when i try and open the file, it wont, its a plain mpg file, do i need to convert it over to avi or something? thanks
You do not need to have Sub Station Alpha. The Subtitle script only follows this SSA format.
If you already have VirtualDub(if not download and install-link given above), download the Subtitler filter(from the VirtualDub page itself) and follow instructions to install it.
Subtitles are entered in a text file(extn .ssa) in a specified format(you can find a sample along with the Subtitler filter you download). Note that this is not an easy task.
MPEG-1 files can be opened using VirtualDub. Apply the Subtitler filter and frameserver to TMPGEnc to create you new MPEG. -
cozmickind,
log to doom9.org, they have a good section for making subtitle.
1. use subrip to rip the desired subtitle into a text file (srt). This file will include the starting/ending point so you don't have to calculate them again
2. use any text editor (notepad) to "translate" or create your own words.
3. use SRTtoSSA to convert the text file to ssa format
4. use virtualdup with subtitle filter to merge your text into the scene.
I did this before and it worked. Hope this help.
Adding/editing subtitles with .ts material (BluRay-rip)??
By Totaldental in forum SubtitleReplies: 4Last Post: 7th Sep 2014, 07:36 -
menu editing and audio/subtitles?
By asiafan in forum Authoring (Blu-ray)Replies: 0Last Post: 26th Feb 2011, 11:37 -
Adding/editing subtitles to an existing DVD without re-authoring?
By frankiewode in forum SubtitleReplies: 1Last Post: 2nd Nov 2010, 19:43 -
Editing Integrated/Embedded Subtitles
By Ofelas in forum SubtitleReplies: 3Last Post: 28th Jan 2010, 16:12 -
Editing subtitles in .avi file
By telecomguy9 in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2007, 13:15
