I have installed SVCD2DVD, Version 2.1 (Build 2.1.2308) and DVD Shrink, Version 3.2.0.15. I am very satisfied with the performance of SVCD2DVD.
However, when I go to General Setting: Other and check "Shrink to fit with DVD Shrink", this option has DVD Shrink (NOT INSTALLED) appended to it. I know DVD Shrink is installed and operational, because I have successfuly used it with DVD Decrypter. DVD Shrink is installed in C:\Program Files\DVD Shrink.
Do I have to uninstall DVD Shrink Version 3.2.0.15 and install Version 3.2.0.14? And if, so where can I obtain this older version of DVD Shrink? Is there another fix for this problem?
SVCD2DVD looks @ the following registry key for DVDShrink:
HKEY_CURRENT_USER\Software\DVD Shrink\DVD Shrink 3.2\Preferences\InstallApp
So make sure that key exists and the the value is to location of the dvdshrink exe (should be C:\Program Files\DVD Shrink\DVD Shrink 3.2.exe) in your case.
If this is not the case then either add/edit by hand or probably a reinstall of shrink should do the job.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I uninstalled DVD Shrink and reinstalled it. That did the trick!!!
Thank you for your prompt reply and solution to my minor problem.Joseph P Moffa -
Just curious...why would you even want to use DVDShrink with SVCD2DVD? Seems to me that you would be encoding once and transcoding once. Isn't that worse for the video than just encoding once? Why not just use "Fit to DVD" on SVCD2DVD and do it right the first time? I am not saying that it is right or wrong, I am really curious about this. Maybe you can convince me that I am missing something.
Thanks,
Mark -
DVDShrink comes into play when you are using .mpeg assets. Since .mpeg's are not re-encoded (except for audio) and only de- and re-muxed the file sizes aren't changed (exept for audio overhead, so a 400MB file might become a 405MB file), "autofit" doesn't work on DVD's authored this way with S2D.
Say you have 5 assets totaling 4.8GB. Too big for a DVD5, but to lose 1 file will give a DVD of 3.84GB (too much wasted space for some) and another of .96GB (a lot of wasted space), so you author the 4.8GB DVD, shrink to 91% (a very acceptable level) with DVDShrink and burn a full 4.37GB DVD with all 5 assets.Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
BD-R (Ver. 1.1 1L), BD-RE (Ver. 2.1 1L) discs
By mobie29 in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jun 2010, 15:57 -
Dynex DVD -R are not recognized on PC
By cmmark in forum MediaReplies: 11Last Post: 13th Mar 2008, 23:48 -
How can I know if DVD-RW media is CPRM compatible ver 1.1 1.2
By bill_dom in forum MediaReplies: 6Last Post: 3rd Dec 2007, 19:53 -
dvd burner not recognized
By agent222 in forum DVD RippingReplies: 1Last Post: 15th Aug 2007, 10:06 -
DVD has (2) versions WS & std, how to back up only WS ver ?
By theewizard in forum DVD RippingReplies: 9Last Post: 6th Jun 2007, 17:00
