can you really hear the difference in sound quality?how which one sound better than the other?
Results 1 to 9 of 9
Not me, but I'm sure some can.
/Mats -
It depends on the source and the playback equipment. If you have low quality source, such as MP3 compressed audio, then no, you probably wont. This is because the audio has already been damaged.
If you have good quality source, then even if you only have TV speakers now, you should use 192 or even 256 kbps for stereo AC3 because one day you may well have better equipment, and you will be able to hear the difference. Once you throw the information away, you can't get it back.Read my blog here.
hmmm well i tried hearing the difference on my computer and i could definitely tell a difference. 128kbps sounds much lower.192kbps sounds much louder and clearerOriginally Posted by guns1inger
What quality was your source ?
And at least you tried it for yourself, instead of just taking everyone's word for an answer.
Personally, I would never go lower than 192 kbps for AC3 anyway, and usually use 256 kbps for 2.0 and 320 - 448 kbps for 5.1Read my blog here.
Typically for commercial movies a vast majority of movies tend to be about 348 kbps (I don't remember the exact number but its between 256 and 448 on the audio scale). That tends to be the sweet spot apparently for hollywood. Now action movies usually do 448.
My dvd recorder (liteon) is fixed at 256 and sounds just fine. My hdtv capture card recording software is fixed to 256 as well.
Personally I don't think you'll save much space by going with 128 versus 192. You'll probably be better off using 192 to keep whatever quality is on the original source.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The production people (Hollywood, etc.) are targeting home equipment three-five years out. Most home 5.1 equipment now is K-Mart level. Also, average people are still training their ears.
There will always be a minority with the audiophile equipment and those sensitive people that complain loudly about overcompression. The typical customer should appreciate these critics. They are protecting your future home theater hardware investment. -
For straight stereo, no but Dolby Laboratories say anything less than 192kbs is inadequate for surround sound and personal testing tends to bear that out.Originally Posted by Bullet2k4
(kim) -
I think you'll find it's 384kbps, which is the max for MP2. For the record, I've found the most common formats to be AC3 2ch 192kbps or AC3 5.1ch 448kbps on the DVDs I;'ve purchased.Originally Posted by yoda313
I agree. 64kbps corresponds to a saving of around 56MB across a 120 minute video so you'd need to be really cramming to consider doing it solely for space purposes IMHO.Originally Posted by yoda313If in doubt, Google it.
Difference Between DTS 5.1 & Dolby Digital AC3 5.1
By dorababu in forum AudioReplies: 8Last Post: 31st Mar 2013, 22:31 -
What's the difference betwen AAC, AC3, and DTS audio's for movies?
By Eagleman in forum AudioReplies: 3Last Post: 29th Aug 2011, 14:36 -
Difference between ac3 and acc
By nicknack74 in forum AudioReplies: 1Last Post: 26th Jul 2011, 05:48 -
after vob Demux the m2v and ac3 have duration difference
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2010, 02:45 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24
