How can I convert a mpeg file to a dvd with having it playing like a badly dubbed film?
Basically, you just author it, provided the mpg is DVD specs. Else, it has to be reencoded to DVD specs, the authored.
/Mats -
Another possibility is you could be using bad media. If you've burned it to dvd and it has problems try a different brand of discs. Also on cheaper media try not to fill the entire disc. Cheap discs have tendencies to break up on the outer edges.
Sony HDR-SR1 and MTS File Conversion to MPEG
By cptspoofy in forum Video ConversionReplies: 8Last Post: 16th May 2011, 13:24 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 13:57 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36
