which one is better?
SONY RDRGX210
PANASONIC DMR-ES10
they are both around about £100 mark from ebay, i chose those 2 because i cant find anything cheaper than that does the following:-
1) 6h+ recording time
2) dual format recording & playback
3) DV input
Unless UK versions are different than US versions, the ES10 does not have a DV input and is limited to dvd+r on the +side but does dvd-r, dvd-rw, and dvd-ram on the minus side.
thanks for letting me know i can cross the panasonic off the list then
Help / 2nd opinion / advice needed from video experts - See attached Images
By sanchopanza in forum Video ConversionReplies: 5Last Post: 18th Mar 2011, 16:22 -
I value your opinion.
By circanow73 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Dec 2010, 14:22 -
Your Opinion of Windows 7
By frieday in forum ComputerReplies: 31Last Post: 13th Jan 2010, 13:50 -
Laptop Opinion
By Poppa_Meth in forum ComputerReplies: 15Last Post: 7th Jun 2009, 12:16 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
