The DAR flag can easily be changed with DVDpatcher
/Mats -
DAR stands for Display Aspect Ratio. It's the aspect ratio at which the final picture is supposed to be displayed (regardless of the frame dimensions). For example, both 16:9 and 4:3 DVDs may both use a 720x480 frame. The only difference is the DAR which tells the DVD player how to display it.
If a 16:9 video is changed to 4:3 using DVDPatcher the picture will be displayed as 4:3 but everything will look tall and skinny.
Do what I suggested earlier. -
...if not everything looks short and wide when viewed at 16:9.Originally Posted by jagabo
/Mats -
Wht would you want to do this ? Unless your disc has something wrong with it - which at the moment is just a guess as you haven't actually described a problem - there is no reason to change the output. If your player is set up correctly then a 16:9 disc will play correctly on a 4:3 TV.
Read my blog here.
I was converting a file not a dvd
the file was not displaying properly I always need to stretch the display to be more larger because everything was looking all sweezed.
And I also wanted a 4:3 format not a 16:9
So thanx for the suggestion DVDPatcher worked fine
Editing MPG2
By danielmak in forum MacReplies: 16Last Post: 17th Feb 2010, 18:28 -
demuxing mpg2
By volam in forum EditingReplies: 1Last Post: 11th Jul 2008, 15:05 -
Convert video from 2-disc dvd to one mpg2
By gamingexpert13 in forum Video ConversionReplies: 12Last Post: 17th Oct 2007, 05:59 -
Convert mpg2 to mpg for Movie Maker
By Cattis in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 14:01 -
MPG2 or MPG4???
By JennyBear in forum Newbie / General discussionsReplies: 7Last Post: 1st Aug 2007, 18:33
