  1. ive downloaded a film and its 2 cds in cue/bin files and i want 2 join them together and put it on to dvd is this possible or will i have to put them on seperate cds thanks andy
    Jan 2004
    First extract what's in the bin files (VCDGear will do this). They will 'usually' be mpeg files. Encode each file to mpeg2 format-encode SEPARATELY; do not join at this stage-it can result in sync issues.
    Once encoded-author them to DVD spec (add each file into app:-track1, track2 etc). I use TDA-excellent for easy use. This will then join them for you and output as AUDIO_TS and VIDEO_TS folders with both files contained within. Burn to disc. Job done!
    TIP: If adding chapters to each file, then delete the 1st chapter of the 2nd file; that way you should be able to avoid a very slight transition between files. Generally, when you add chapters, the app quite often puts a chapter at the very beginning of each file. This way you avoid that 1st chapter of the 2nd file.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Depends on what's inside those BINs. A bin is just like a bucket - it can contain just about anything.
    If it's VCD, then yes, VCDGear wil do the trick, but then, you don't have to reencode, as a VCD mpg can be authored right away with TDA.
    /Mats
    Jan 2004
    True, can author without encoding, if sticking with VCD-but VCD is still mpeg1 though. If full DVD spec is required then surely you need to encode to mpeg2.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    VCD video is DVD specs. Reencoding to mpeg-2 will only lower quality further. The not DVD specs about a VCD mpg is the audio sampling fq, but TDA fixes that part transpatently.
    So, authoring a VCD specs mpg with TDA results in a 100% Video DVD specs DVD.
    /Mats
    Jan 2004
    Thanks Mats. Yes, knew about the audio but not the video. I've only being doing this for about last 2-3yrs and i never knew that!!!!
    I remember when i started out and knew absolutely nothing, i just read a load of stuff; a bit here, a bit there and they all seem to say that, to get to dvd format, then you must first get to mp2. I naturally assumed that every file i get, MUST be be encoded to mp2 format!
    How wrong am I. It just shows that i should have read MORE!!!!!! Thanks again and apologies for the naiviety.
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    The beauty of this business - There's always something new to learn each day!
    /Mats
  8. thanks ever1 got it sorted with your help
