    Jun 2006
    Australia
    I was cleaning up my system and found a bunch of .viv and .m2p movie files. I found something to play/convert m2p files but I can’t find anything so far to convert the .viv files. Just curious to see what they are before I delete them. Any suggestions?
    Also when I converted the m2p files they had no sound. Now quite possible the original had no sound either. I can’t recall. But is there a codec/player that can play these files I can use to confirm if the in fact they have no sound?
    Thanks in advance for any help!
    Aug 2005
    Right here
    Googled this for you:
    http://www.fileinfo.net/extension/viv
    HTH
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety. (Benjamin Franklin).
    USA
    SUPER may be able to convert the vivoactive files. .m2p could be the file extension for the Canopus MPEG-2 video file. If so, you should be able to check it with Gspot 2.52 to see if there is any audio.
    Jun 2006
    Australia
    HTH
    I have the RA codec and it doesnt seem to be recognised by it. However I want to convert them not just play them. Thanks though.
    Jun 2006
    Australia
    Super doesnt convert and gspot shows n/a for m2p files in both audio and video.
    Aug 2005
    Right here
    Looks like mplayer can play vivo files, as I've read here
    http://www.mplayerhq.hu/design7/info.html
    If so, mencoder should convert them
    https://www.videohelp.com/tools?tool=MPlayer
    Command line tool, though
    Cheers
    Jun 2006
    Australia
    Cheers
    Thanks. Played around with it for a while but its too annoying for me to persavere with it. It didnt detect any of my installed codecs. Would be nice if it had a gui. Even a simple one.
