Hello again...
This time I'm having a flicker problem.
Working in Premiere 2.0
Captured footage NTSC 29.97 Lower field
I exported progressive. Is this my mistake?
Encoded in Encore.
When I playback on tv, I have flicker problems. Very jittery video, almost makes you dizzy looking at it, as well as horizontal banding issues especially during dynamic (fast) movements of a subject.
To fix this, should I use the Field Options settings in Premiere and set it to Flicker removal for every clip? Or is this simply due to an interlacing setting?
Watching the exported m2v on WMP doesn't have the jitteryness but still has the horizontal banding problem.
THANKS FOR ALL THE HELP!!!
- Dan
Depends on the source and capture device.
If this is normal video (not film source) and if the capture device is a generic tuner, then top field first is the correct project setting and encoding top field first (interlace) will get you full motion 59.94 fields per second. Consider this the default unless you have a reason to encode progressive.
Progressive conversion can be done several ways with different affects on motion. This oftern results in half motion resolution and flicker on an interlace display (tv).
Here are the basics.
http://en.wikipedia.org/wiki/Deinterlace
This explains film telecine, line doubling for progressive display and progressive DVD player basics.
http://www.dvdfile.com/news/special_report/production_a_z/3_2_pulldown.htm
Annoying flicker from 8 mm film
By mexuser in forum Newbie / General discussionsReplies: 3Last Post: 29th Mar 2011, 19:31 -
Computer Monitor Flicker Problem
By Xenon77 in forum ComputerReplies: 2Last Post: 7th Sep 2009, 16:15 -
Strange flicker on my DVD-Rs
By ministry88 in forum DVD & Blu-ray RecordersReplies: 17Last Post: 6th Mar 2009, 22:43 -
DVD to Adobe Premiere Frame Flicker Problem
By bighurt in forum Video ConversionReplies: 2Last Post: 6th Feb 2009, 12:32 -
Flicker effect
By wan2no in forum EditingReplies: 1Last Post: 26th Jul 2007, 20:38
