can anybody advise how i can convert a movie downloaded to my pc by skybybroadband so i can play on my normal dvd player on the domestic tv
Hi,
I'm not familiar with this service. However presuming your contract with Sky allows you to transfer downloaded movies to DVD:
Can you please state what format the downloaded movie is in - AVI ? MPEG 1/2 ? Other ?
In general you will need to re-encode your video file to a (DVD compliant) MPEG2 file, using a video encoder (see the tools section on the left).
Then you can load this MPEG2 file into a DVD authoring software (see tools again) and create the necessary DVD files (.bup .ifo .vob).
Then you can use a burning software (tools) to burn to a blank disc.
Best of luck,
moonstomp.Just because you're nobody, doesn't mean that you're no good. Just because there's a reason, doesn't mean it's understood. It doesn't make it all right ! (The Specials) -
sorry, there's no way to bypass the DRM and make it a DVD-video. the only thing you can do is watch it on your computer...thats bout it.Originally Posted by fred12ned
you can remove the drm from sky broadband movies what you do is
1 download movie
2 use tunebite plat ed to remove drm then convert file to dvd or avi what ever you need
3 burn to dvd
thats it
it works -
Try FairUse4WM
He's a liar and a murderer, and I say that with all due respect.
DVD recorder won`t let me watch Sky
By edwards in forum DVD & Blu-ray RecordersReplies: 1Last Post: 4th Aug 2011, 14:06 -
Mini DV to DVD and Sky HD to DVD, one piece of Hardware ?
By steveh771 in forum Newbie / General discussionsReplies: 0Last Post: 10th Feb 2009, 07:39 -
Changing Broadband From AOL To Sky Help
By Nitro89 in forum Off topicReplies: 0Last Post: 12th Dec 2008, 15:36 -
Sky + And/Or Sky HD Recording To Pc With DAZZLE
By akenny01 in forum Capturing and VCRReplies: 0Last Post: 7th Mar 2008, 19:02 -
Sky+ recording to dvd help!
By dollydoodledumplin in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2007, 01:25
