On a typical Blank 4.7GB DVD+R disk, what is the best end format for time?
For example, If I have a .avi that needs converting to a mpeg2 or SVCD or VCD or DVD so my magnavox MDV458 DVD player can read it, then what is the end format most people would use.
What format allows for the most time to GB ratio of video play?
What is your fav program for this?
Thanks,
Steve[/b]
Hi SteveF22,
A DVD+R (or -R for that matter) with VCD resolution / bitrate, but with DVD compliant MP2 or AC3 audio (i.e. 48KHz) would yield the most running time on the disc.
If you really want to squeeze loads on, have the simplest of menu - or even none at all...
Encode to MPEG1 (VCD) video only using TMPGEnc (it's free for MPEG1), and encode the audio in the AVI to MP2 or AC3 using ffmpeggui, making sure the audio is at 48KHz, and around 192 - 256 kbps, depending on the quality of the original.
Author to DVD using any number of basic authoring tools, including free ones. Look in the "Tools" section, "DVD Authoring" category...
However, VCD is the lowest quality. There's always a trade off between quality and running time - more of one, less of the other...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
If you are making a standard high quality DVD to play on a settop player, only MPEG-2 will work. If you have a Divx DVD player, then you can use that format.
For the DVD specification, look to the upper left for 'What is' DVD. <<<<<< You can vary the bitrate and the audio format somewhat, but to be a compliant DVD, it has to be MPEG-2 or MPEG-1. (lower quality similar to a VCD)
If you are asking about the most effecient format, that's debatable. H264 is very good, but very few settop players can use it. The Nero Digital is also right up there.
Divx may be a good choice if you want small file size and decent quality with fair compatibility with Divx settop players. There are a lot of Divx/Xvid settop players on the market presently.
For most Divx/Xvid conversions, I use VirtualDub Mod. A couple of all in one converters that are popular are AutoGK and my favorite, FairUse Wizard. -
Thanks Red for the informative info, and I didnt know DVDs only held 4.38GB, thats the fleeceing of America or what?
Ya, my magnavox only handles standard MPEG1 or 2.
Lets say that I have a file that is 600mpeg as an .AVI
Convert to mpeg2 high quality = 2.23GB
Convert to DIVX is = ?GB
What would that number be? -
There is no magic formula, other than what a bitrate calculator will give you. There is no direct correlation between mpeg-2 and mpeg-4 file sizes.
If you avi file is 600 mb, it could well be Divx. Use g-spot or avicodec to confirm. If it is Xvid and you use the same settings in Divx, you will get the same file size.Read my blog here.
If your AVI is 600M as an AVI, there is a good chance it is already DIVXOriginally Posted by SteveF22
Terje A. Bergesen -
Thx, vid is allready DIVX, I gotta find a player that plays divx, u get so much more with less then half the space.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
