is this a monitor with built in speakers or do you have a special keyboard with volume control and a software that shows the volume bar? More information is needed.
******** PROBLEM SOLVED **********
Thanks greymalkin for responding. Sorry for not replying sooner.
Here's my problem...
When I press the up/down audio buttons on my HP keyboard, a visual indicator displays on screen showing the sound level. The volume bars no longer display. No speakers on the monitor.
I went to the HP site and they did have a software/driver update, but it did not work once I turned off and on the PC.
My PC is a HP Media Center m7250n
If I can't find a solution, I'll contact HP this weekend.
Here's an illustration:
[/img]
i think you should have a program called "OSD.exe" in the startup folder. see if it's running...
I am just a worthless liar,
I am just an imbecil
Problem with the monitor: showing only white screen
By 1234567 in forum ComputerReplies: 0Last Post: 8th Aug 2010, 13:26 -
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 12:39 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 08:43 -
ffmpeg seek bar (or timing bar)
By Seven40Rob in forum ffmpegX general discussionReplies: 1Last Post: 8th Oct 2008, 00:36 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 22:29
