    Apr 2005
    Norther California
    I need to convert a bunch of old vhs tapes to dvd, and for some reason, my K-world mce-200 is not working with Sony Movie Studio. It says
    The Device 'Conexant 2388x Video Capture' could not be opened
    Please make sure that it is turned on and is not being used by another application or user
    Does anyone know what to do with a problem like this? I have installed the latest version of the program, and the capture card drivers. Please help!
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    Conexant 2388 is not on list of approved capture devices for sony vegas , Vegas is designed to work with DV (firewire), HDV, Blackmagic and stand alone firewire based transfer devices
    Jul 2003
    LA - Lower Alabama
    You will need to capture your VHS tapes with another application and then import the captured avi into Sony Vegas Movie Studio. A few recommendations would be virtualdub or virtualvcr.
    It may be possible, if you have a camcorder with the capability, to use the passthrough function. Hook your vcr to your camcorder and camcorder via firewire to your computer.
    Apr 2005
    Norther California
    Thanks guys, you helped out alot. I remembered that we do have a digital video camera that can do an analog pass-through. It works great with Vegas movie studio.
    Thanks guys,
    the mersh
