Sorry but i tried a search and i kept getting this....."Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 524288 bytes) in /var/www/html/videohelp/forum/search.php on line 445"
Anyway how do i convert a DVD to mpg?
I have a 1.19GB DVD that i would like to make into several mpg's. This is a DVD out of my Camcorder.
Results 1 to 11 of 11
Mark V
10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D -
Thanks a bunch. I am converting the DVD now.
Mark V
How do i save it with audio?
Mark V
Doh! I think i figured it out.
Mark V
Yep i saved the 1st one the wrong way so it got no audio. I figured it out the 2nd time.
Thanks again.Mark V
How do i cut the video up in smaller mpg's?
cut, copy, past and delete in my Quicktime are not highlighted like in other mpg's i have. Normally i cut them up into smaller mpg's this way.Mark V
You can set in/out points in MPEG Streamclip and use cut/copy/paste.
I seen that but didnt understand how it exactly works, i ended up doing everything wrong. Is there an online how-to do this exactly anywhere?
I have 1 long mpg like 768mb, it has about 8 different videos in it. When i tried to edit it with MPEG StreamClip i was deleteing things i didnt want to.
With quicktime i can cut and paste in different players.Mark V
You can set the in / out points of the file you want to save, and then choose one of the options in the file menu, such as "convert to MPEG." This will create a file using just the section delineated by the in / out points.
Hint: 1. Use the "i" and "o" keys to set the in / out.
2. Use the zoom to expand the timeline
3. Always use "Fix Timecode Breaks" with vobs -
Ok i figured it out. It has to be exported to Quicktime and then i can cut and past very easy.
Mark V
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 18:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
