Hello!
Is there anything on the Mac i can use to extract the audio from a non standard VCD mpg/DAT file so i can re encode it properly? I've done this with VirtualDub in VPC, but I would prefer to do it in the Mac?
Jerry
to extract audio from a MPG you could use the mpgtx package available for OS9 and OSX at http://www.biermann.org/philipp/mpegcut/
install the latest version, put your MPG in the same directory, run and type mpgdemux movie.mpg which will chunk your MPG file into a .mp2 sound file and a .m1v video file -
hello!
Great. Thanks. Do you know of any program on thr mac that will display the video and audio format, codec, etc used in a video?
My problem has been downloading video in various formats to convert to VCD. In most cases a quick run through VCDgear makes them Toast ready. But i think the last couple VCD mpg i downloaded have non standard audio. A different type of compression that toast doesn't like.
If it's just a mater of splitting the audio from the video, converting the audio and re-encoding that is easy. I'd rather not have to recompress the video stream if the trouble is only audio format.
Jerry
to analyze a MPG file you can use that very same mpgtx package, the command is mpgtx -i movie.mpg
if you are on OSX a GUI port of the same software is also available at
http://www.sbpr.a.se/systemjammers/mpeginfo/index.html
VCD compliant streams must be system streams of 1150 kbit/sec MPEG-1 for video (352 x 288 pixels @ 25 frames/second or 352 x 240 pixels @ 29,97 frames/second) and 224 kbit/sec stereo MPEG-1 Layer2 for audio.
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
How to extract audio from mpg file?
By paul.1911 in forum AudioReplies: 4Last Post: 9th Nov 2010, 03:35 -
How to extract Teletext substream from mpg ?
By Robertus in forum SubtitleReplies: 11Last Post: 27th Sep 2010, 09:49 -
Extract Subtitle Stream from MPG (Used VOB2MPG to create file)
By secretsubscriber in forum SubtitleReplies: 2Last Post: 4th Jun 2009, 14:02 -
Extract Audio from MPG
By vin4evr in forum AudioReplies: 3Last Post: 24th Dec 2007, 13:09
