Hello All,
I've been using this program without a hitch for the past 6-8 months until now. Now it keeps spitting back out whatever I set to convert. It either gets the below error, or just locks up the computer. All the videos have been ckecked with video inspecter and my codecs are up to date. Any help?
18/06/2006 8:32:22 PM info ********** Report session closed ***********
18/06/2006 8:20:25 PM info --------------Encoding end--------------
18/06/2006 8:19:02 PM info Conversion failed after 00:12:32
18/06/2006 8:19:02 PM error Exception raised in conversion Thread with message "Access violation at address 1000CD8A in module 'avcodec.dll'. Read of address 000004EF"
18/06/2006 8:17:01 PM info Chapter #3 start at 10:0.120
18/06/2006 8:11:41 PM info Chapter #2 start at 4:59.960
18/06/2006 8:06:31 PM info Stream #1 Sync. delay : 0.00 ms
18/06/2006 8:06:31 PM info Stream #0 Sync. delay : 0.00 ms
18/06/2006 8:06:31 PM info Output Stream#1 - Audio: ac3, 48000 Hz, stereo, 192 kb/s
18/06/2006 8:06:31 PM info Output Stream#0 - Video: mpeg2video, yuv420p, 720x576, q=2-31, 3360 kb/s
18/06/2006 8:06:30 PM info Video Stream #0 framerate : 25.00 Fps (source 25.00 Fps), no pulldown
18/06/2006 8:06:30 PM info Padded source image : Left 0, Top 48, Right 0, Bottom 48
18/06/2006 8:06:30 PM info Video source original frame rate: 25.00
18/06/2006 8:06:30 PM info PAL 25 FPS output format set by user
18/06/2006 8:06:30 PM info Widescreen (16:9) set automatically
18/06/2006 8:06:30 PM info Video bitrate 0/3360/8308 Kbps (min/avg/max)
18/06/2006 8:06:30 PM info Converting "C:\Documents and Settings\Nicholas\My Documents\New Folder\cars\x.avi"
18/06/2006 8:06:30 PM info ----------------Title #1----------------
18/06/2006 8:06:30 PM info Project size 4.3 Gb. (156 Mb. audio - 2.78 Gb. video - 1.36 Gb. originals)
18/06/2006 8:06:30 PM info Stream #1 - Audio: mp3, 44100 Hz, stereo, 224 kb/s
18/06/2006 8:06:30 PM info Stream #0 - Video: mpeg4, yuv420p, 704x320
18/06/2006 8:06:30 PM info 2 Stream(s) found - est. duration 00:58:44.040
18/06/2006 8:06:30 PM info Opening file "C:\Documents and Settings\Nicholas\My Documents\New Folder\x\x.avi"
18/06/2006 8:06:30 PM info Stream #1 - Audio: mp3, 44100 Hz, stereo, 128 kb/s
18/06/2006 8:06:30 PM info 2 Stream(s) found - est. duration 00:55:00.000
18/06/2006 8:06:30 PM info Opening file "C:\Documents and Settings\Nicholas\My Documents\New Folder\x\x2.avi"
18/06/2006 8:06:28 PM info New media inserted. Burning layer is ready to write
18/06/2006 8:06:27 PM info [ ] Engine Log
18/06/2006 8:06:27 PM info Encoder quality: 50%
18/06/2006 8:06:27 PM info --------------Encoding begin--------------
18/06/2006 8:06:27 PM info --------------Menu settings end--------------
18/06/2006 8:06:27 PM info [X] Sequential playback
18/06/2006 8:06:27 PM info [X] Loop Playback
18/06/2006 8:06:27 PM info [X] Auto start playback
18/06/2006 8:06:27 PM info [X] Menu
18/06/2006 8:06:27 PM info --------------Menu settings begin--------------
18/06/2006 8:06:27 PM info --------------Default burn settings end--------------
18/06/2006 8:06:27 PM info Default speed selected: Max
18/06/2006 8:06:27 PM info Compatible media types : DVD-R, DVD-RW Seq., DVD-RW RO, DVDRAM, DVD+R, DVD+RW, CD-R, CD-RW, DL DVD+R
18/06/2006 8:06:27 PM info New Drive selected : 1:1:0 - HL-DT-ST DVDRAM GSA-4120B A117 [F] (Ide)
18/06/2006 8:06:27 PM info [X] Delete files after burn complete
18/06/2006 8:06:27 PM info [ ] Don't eject after burn complete
18/06/2006 8:06:27 PM info [ ] Prefer SAO for DVD-R
18/06/2006 8:06:27 PM info [X] Include originals
18/06/2006 8:06:27 PM info [X] Burn result to DVD
18/06/2006 8:06:27 PM info --------------Default burn settings begin--------------
18/06/2006 8:06:00 PM info New media inserted. Burning layer is ready to write
18/06/2006 8:05:57 PM info User default language : 4105 (0x1009h) - English (Canadian)
18/06/2006 8:05:57 PM info System default language : 1033 (0x0409h) - English (United States)
18/06/2006 8:05:57 PM info Version 2.0.13.128
18/06/2006 8:05:57 PM info ExeName : "C:\Program Files\vso\ConvertXtoDVD\ConvertXtoDvd.exe"
18/06/2006 8:05:57 PM info OS : Microsoft Windows XP Personal Service Pack 2 (Build 2600)
18/06/2006 8:05:57 PM info ******************** Report session started ********************
I recently reformatted, but the problem existed before the reformat and after. I have the k-lite codec pack and i do have the latest version of convertxtodvd.
Codec packs generally are a bad idea. They often contain conflicts between software, bastardised installers and can cause all sorts of problems. They are also difficult to uninstall because of the way they are cobbled together. This could be the cause of your problem.
I suggest contacting VSO supprt to see if they can shed any light on the problem, and in the meantime, uninstall the codec pack and just install the specific codecs you require, using the proper installers.Read my blog here.
Subtitle problems using convertxtodvd
By gtorres001 in forum Authoring (DVD)Replies: 41Last Post: 3rd Mar 2012, 02:36 -
Convertxtodvd causes sound synch problems with some films
By johnharlin in forum Authoring (DVD)Replies: 1Last Post: 6th Oct 2009, 01:15 -
Problems converting using ConvertXtoDVD
By nadizo in forum Video ConversionReplies: 4Last Post: 10th Jun 2008, 21:29 -
ConvertXtoDVD v2.2.3.258 Problems..Jerky Video...
By sandman423 in forum Authoring (DVD)Replies: 6Last Post: 4th Dec 2007, 14:06 -
ConvertxtoDVD and DVD flick problems any help.
By jarbasss in forum Video ConversionReplies: 5Last Post: 16th Nov 2007, 13:50
