    Jul 2001
    Maryland
    I cannot capture sound./
    When i go to select a profile none have sound.
    I go to the create new and the "audio format" is grayed out.
    I have an ATI All in Wonder 128 Pro with MM 7.5
  2. Did you run the initialization wizard? It is under the Video tab. So, runt the initialization wizard and eventually you can select what audio input you want to use.
    Jul 2001
    Maryland
    That's not what i mean.
    When i create an profile, i cannot select an audio format n the mpeg's n avi's r without sound.
  4. What does the Device Manager say about your soundcard drivers?? Have you un-installed and re-installed your soundcard?? Do playing MP3s work?? What is your sound card?
    Jul 2001
    Maryland
    Crystal Fusion MMX.
    I dun even know how to un-install it.
    It came with the computer.
    it's a piece of crap.
  6. Control Panel--->System--->In Win9x there is a tab for Hardware, in Win2k/XP click on the tab Hardware, then Device Manager. Select your sound card (you'll see it). right click and Uninstall. Reboot and the computer should find your card again - and install new drivers.
