When converting video files to DVD format, would you recommend WinAVI or TMPGEnc? I have always used TMPGEnc but since I just got WinAVI to convert RMVB to MPEG2, I find it's pretty straightforward and easy to use.
1.) Which one is better in producing quality DVDs?
2.) Can WinAVI accept input from MP4, MKV, OGM, etc.?
Results 1 to 9 of 9
I for one would avoid Winavi,it may seem straight forward but you wont be happy with the outcome for example you are already having problems.
If you stick with a tested and high standard tool like TMPGEnc you will be fine.Downside is that it isn't as straight forward but then again it wont take very long to master the settings.
~Luke~ -
WinAVI is not that good at (trans)encoding, but its ridiculously easy to use. Its also very fast.
I think its pretty well agreed that if you dont know what you are doing, and need something usable in your hand, winAVI fits the bill.
If you have a bit of knowledge, and dont mind reading up on stuff to figure out how to use it, best to use a more advanced tool(s) to get better results. -
Without knowing WinAVI, I'd guess there's probably a setting somewhere to tell it to split (into elementary streams such as seperate audio and video, or more than one video file (each with audio and video)?).Originally Posted by Sakuya
You can also try other encoders such as SUPER (which is really just a frontend to ffmpeg, mencoder and some other CLI encoders).If cameras add ten pounds, why would people want to eat them? -
After experimenting, WinAVI is actually not that bad. It gets the job done quickly for weird formats and codecs like MP4 and RMVB and I do not have to make all those AviSynth scripts for TMPGEnc because TMPGEnc does not accept those formats. I guess I will use both depending on what kind of format I have.
Winavi problem
By Qvezzy in forum Video ConversionReplies: 2Last Post: 3rd Mar 2010, 16:21 -
What am I doing wrong with WinAVi?
By alex0000 in forum Video ConversionReplies: 1Last Post: 7th Feb 2010, 08:27 -
I can't use WinAvi 9.0.
By dualinline in forum Video ConversionReplies: 2Last Post: 19th May 2009, 08:47 -
Winavi 8.0 Help
By agkoichi in forum Video ConversionReplies: 1Last Post: 26th Jul 2007, 04:17
